How to install a Brake Controller?
Old May 14, 2015 | 02:37 PM
SoCalAngler's Avatar
SoCalAngler
Just picked up a small 5er. I need to install a brake controller. I was told that these older trucks did not come with preinstalled brake wiring and that the entire install has to be all hard wired....meaning there are no plug and play connectors.
Was considering the Tekonsha P3
Tekonsha - P3®
Are there plug and play adapters/connectors for OBS trucks, specially 1992? If so, do you have a vendor name/link?
This is all I could find that involves hardwiring on one end.....
http://www.tekonsha.com/products/bra...n30pJXsyWTZqGv
Old May 14, 2015 | 04:17 PM
bashby's Avatar
bashby
You should have the connector under the ashtray. The older trucks have a different connector than the new stuff and I had a hard time finding the right one. I just cut it off and hard wired it. I figure it's one less failure point. I REALLY like the but connectors that have the heat shrink insulator on them. The ones like what comes with that adapter you linked can allow the wire to bend back and forth at the connector and eventually break. I believe they are bigger than they need to be also. The P3 is a very good controller.
Old May 14, 2015 | 05:24 PM
SoCalAngler
Are these instructions for a Tekonsha wiring harness for all of our OBS trucks (see link below)?
Does it depend on whether or not I have a tow package wiring?
If so, how do I know if I have the two package wiring?
http://www.tekonsha.com/support/installation/N15262.pdf
Old May 14, 2015 | 05:29 PM
sgip2000's Avatar
sgip2000
I have a P3 in my 1995 F250 and it uses this harness.
Ford brake controller harness Ford brake controller harness
Old May 14, 2015 | 05:30 PM
sgip2000's Avatar
sgip2000
Check my gallery. I have photos of the connectors there.
Old May 14, 2015 | 05:40 PM
SoCalAngler
Something on our trucks must have changed between '92 and '95 as the Tekonsha website states it will not fit a '92
Old May 14, 2015 | 06:21 PM
sgip2000's Avatar
sgip2000
Said it wouldn't fit mine either.
This is the one Tekonsha says works for your '92, however, it is the same as mine, but without the controller end.
Old May 14, 2015 | 06:35 PM
SoCalAngler
so is it the gray plug that connects under dash and bare wire end to Tekonsha controller? If that's the case, why wouldn't the one for your truck work on mine? It's just an additional plug for the controller, isn't it?
Old May 14, 2015 | 06:37 PM
sgip2000's Avatar
sgip2000
That is correct. Look under your dash in the center for the female version. It's pretty easy to spot.
Old May 14, 2015 | 06:43 PM
bashby's Avatar
bashby
That's why I. Hard wired mine
Old May 14, 2015 | 08:35 PM
subford's Avatar
subford
The 92 had a 4pin plug and the 95 had a 6pin plug. That is the difference.
The 1992 Brake Controller and trailer plug wiring:
Old May 15, 2015 | 03:29 AM
Truck Guy99's Avatar
Truck Guy99
I dunno about the adapter or harness because my truck has one that came with it but I'd also like to know what adapter to get for my 88. I'm replying because I want to say the tekonsha P3 is what I run in my dodge Dually and I love it. Great controller that you can adjust on the fly and if you find the adapter harness they are a cinch to install. I recently pulled 9k on a bumper pull behind my Dually and the p3 rocked. The manual lever on the bottom is a lot easier to grab than most of the controllers I've used and actually prevented me from getting in a wreck when some chick pulled out in front of me while I was going 60 and it stopped on a dime. Just food for thought
Old May 15, 2015 | 07:40 AM
subford's Avatar
subford
Below is all the information on the 1988 F-series Trailer wiring that is in the 1988 manuals.
I do not think they ever came with a trailer plug under the dash.
Old May 15, 2015 | 09:04 AM
Conanski's Avatar
Conanski
91 and older trucks will require all trailer wiring be installed from scratch.. there is nothing pre existing. You can buy a T connector to connect the lighting to your trailer connector from a junction near the rear bumper but all brake controller wiring has to be run from the battery to the controller and on back to the trailer connector.
Old May 15, 2015 | 09:40 AM
Diesel_Brad's Avatar
Diesel_Brad
Also. for the 92-97 trucks in order for the trailer brake controller to plug in and work, you also will want the relay box under the hood. It attaches to the side of the undressed fuse box with 2 screws and has 2 relays in it. (12v and Backup)
here is my thread on it https://www.ford-trucks.com/forums/1...er-wiring.html
