Adding A/C
Old Jun 4, 2007 | 09:18 PM
Your Mom's Avatar
Your Mom
Adding A/C
I've searched around and couldn't really get a good answer. i want to add ac to my truck.
I have a 93 7.3l turbo diesel, what years would be good donor trucks to pull the ac from? does it have to be a diesel?
thanks guys
this truck was orginally from canada so i guess they didn't opt for a/c.
Old Jun 5, 2007 | 03:04 PM
David85's Avatar
David85
thanks guys
The easiest would be to get one off another 7.3L IDI diesel, that way you can take all the brackets and other misc. that are needed at the same time.
If you have some metal fab skill (or know some one who does), than you could scavange from just about any V8 ford that had A/c and a serpentine belt.
Theres alot of stuff both in the cab (air ducting and wiring) as well as under the hood that will require getting in deep.
I should warn you though, putting A/c in a truck that did not originally have it can get ugly, but it can be done.
Old Jun 5, 2007 | 04:17 PM
Hamberger's Avatar
Hamberger
[QUOTE=Your Mom]
I was told when I bought my 93' turbo new that the 93 model year was not available with A/C from Ford due to the interference with the turbo.
93' was the first year with the turbo and Ford had to delete the A/C to make the Turbo fit.
Maybe you could look at a 94' turbo or later truck to see if one of those later A/C systems can be adapted to your truck.
Also all the older systems (pre-95' were setup for R12 refrigerant which is no longer available.
I think your idea to put in an A/C system is going to cost you, probably not worth it in my mind unless you got a really nice truck you are looking to keep running for years to come.
AC = $$$$$$$$$$
Seb.....
Old Jun 5, 2007 | 04:59 PM
Your Mom's Avatar
Your Mom
thanks for the input guys. yeah it might be more $$ than its worth but if i can find the stuff, I can do all the work myself. but i had to figure out what to look for first. then if its stupid $$ then i can just deal with it. the truck only has 113k on it and for a 93 its in pretty decent condition. IMO
thats interesting about the 93's. I guess it might have some interference. So no 93 turbo's had ac? see this is why i asked. learn something new everyday.
hamberger on your 93 does it have the spot for the compressor?
I need to look around for some pictures of each.
what years had the 7.3l IDI? not many right?
pics are kinda big.
pic1
pic2
pic3
Old Jun 5, 2007 | 08:19 PM
David85's Avatar
David85
I would call that a little better that decent condition! I had heard that the 93 turbos did not have A/c, but the turbo pack was made by ATS and has been installed on ford diesels that did have A/c.
We now know that the hp rating of the 7.3 IDI turbo was likely underestimated by ford to encourage people to opt for the new powerstroke instead. I can't help but wonder if the lack of an A/c option was also part of that ploy.
The turbo IDI was avalable from 1993.5-1994.5, and the N/A 7.3 goes back to 1988.
Truth be told, if I were in your shoes, I would also try to retrofit an A/c system into the truck, theres just something wrong about having all the other options and not the cold air.
Old Jun 6, 2007 | 08:47 AM
Hamberger's Avatar
Hamberger
I would have to buy the bracket that supports the Compressor. I do have an idler pulley in place of where the compressor usually sits so my belt is the same as a regular belt on a 7.3l with A/C in theory. Unfortunately the belt has always been a problem on this truck until I switched to a heavyduty tensioner off an F-450 which has made the belt problem liveable. I now atleast manage to get atleast 20k between belt changes.
It would not suprise me if the A/C idler pulley set-up is what is causing all my problems. I replace the idler pulley and bracket twice but the new stuff runs just as crooked as the original. In my mind there is way to much play in the idler pulley. The pulley would need a larger bearing.
If Ford sold the 93' without air so as not to shy away buyer from buying the Powerstroke in 94' I must say they sure screwed up the idler pulley design for where the A/C compressor was supposed to be.
Seb....
Old Jun 6, 2007 | 04:11 PM
dieself250's Avatar
dieself250
here is a complete kit for your truck from ackits.com http://store.ackits.com/merchant.mvc...=AMA13239-7157
I put one of ther kits on my 89, and i am very happy with it
Old Jun 6, 2007 | 05:25 PM
Your Mom's Avatar
Your Mom
wow thats awesome. 1000 bucks though. i was thinking a bit cheaper. was it all custom stuff or did it have factory stuff? Like did the compressor bolt up how a stock one would? do you have pics of yours?
Looks like i need to have a talk with the wife.
Old Jun 6, 2007 | 05:30 PM
Your Mom's Avatar
Your Mom
oh **** the picture shows the climate control panel switch and cover so by the picture its a stock install. but with brand new stuff instead of used. I'm likeing this.
Old Jun 6, 2007 | 06:33 PM
dieself250's Avatar
dieself250
its just like having factory air, every thing is oem stuff except for the hoses, compeser and condenser. and its a 134a system
Old Jun 6, 2007 | 07:00 PM
David85's Avatar
David85
Its not that pricy when you think of all the misc stuff that could nickel and dime you to death. I suspect you may end up spending as much if you were able to source everything from a wrecker.
At least this way all the guess work is done for you.
Old Jun 6, 2007 | 09:58 PM
Your Mom's Avatar
Your Mom
yeah this definatly sounds like the way to go. Gotta see what the wife says.
srteach
Jun 11, 2013 07:48 PM
uscghutch
May 9, 2009 06:51 PM
TxFordGuy
1983 - 2012 Ranger & B-Series
Jul 20, 2006 01:25 PM
datahoarder
Electrical Systems/Wiring
Apr 21, 2005 10:17 PM
oshoguno
Jul 1, 2003 04:53 AM
