Possible pulley problem!!
Old Jan 15, 2009 | 09:52 PM
uscghutch's Avatar
uscghutch
Question Possible pulley problem!!
I have a load screaching sound coming from either the are by the tension pulley or the A/C compressor. Anyone have any pulleys cause problems or their A/C comp? Took it to the dealer and had a diesel mech listen. Said it could be a possible bearing problem in the A/C comp. Truck only has 54k on it.
Old Jan 15, 2009 | 10:31 PM
brickie's Avatar
brickie
With a stechoscope(sp) it is easy to find the noisy bearing. Did your tech use one?
Old Jan 20, 2009 | 02:47 AM
uscghutch's Avatar
uscghutch
I found the upper grooved idler pulley was the probelm. Also changed out the belt. All good to go.
Old Apr 1, 2009 | 02:22 PM
Pitchinfool's Avatar
Pitchinfool
Did you have to buy the pulley from Ford? Mine does the same thing. I was thinking about replacing the tensioner pulley and the idler pulleys while I had it apart. How har a job was it? Thanks.
Old May 9, 2009 | 06:51 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
I know this thread is a little old, but the information in it helped me fix a constant pulley squeak and the belt squeal during shut down on my wife's "new" Excursion (with 121K miles). I ended up replacing the belt tensioner assembly that came with a new idler pulley already installed and a new V-belt.
CarQuest parts used:
Gates - Auto Tensioner - TEN 38257
Gates - Micro V Belt - RBR K081253
On a side note: I'm glad I got the whole tensioner assembly because I was able to remove the old belt off the alternator pulley by hand, so the tensioner was really weak. After I got the tesioner off, the grooved idler pulley ended up being the constant squeak culprit. The V-belt install was a PITA to do by yourself!
abyars111
Feb 26, 2014 09:51 AM
03_PSD
22
Mar 1, 2010 10:02 AM
Nodyroc
1997 - 2003 F150
Mar 7, 2007 06:47 AM
nugecrazy
1997 - 2003 F150
Jul 4, 2006 07:24 PM
i1dery
Jan 5, 2006 11:45 AM
