A/C operation
Old Jun 23, 2003 | 12:31 PM
oshoguno's Avatar
oshoguno
A/C operation
Hi All, since I have no idea how my a/c system works I thought I would ask this question. On my 99 Explorer, how do I know if my a/c is stuck on. With the switch in the blend (feet and vent) position and the temp **** turned to the cool side I am getting a/c out of the vents. With the switch in off my gas milage improves. On the switch blend is to the right of off and the a/c and a/c max are on the left of off. The truck is not hard to start so I don't think the compressor is on all the time (otherwise I would burn out my starter, right?). How is the a/c system supposed to work? Thanks for any help.
Old Jun 24, 2003 | 12:33 PM
steve83's Avatar
steve83
A/C operation
The Haynes manual will explain how it works and how to check it. HowStuffWorks probably has some good animated diagrams, too.
Old Jun 26, 2003 | 04:17 PM
Big Orn's Avatar
Big Orn
A/C operation
That's the way Ford made them - and the A/C is still on in the VENT/FLOOR position even if you turn the heat up. Yep, that's to cool off all us older folks feet!
That's how it is on my '99 SD anyway - factory installed
Old Jun 30, 2003 | 08:25 PM
LxMan1's Avatar
LxMan1
A/C operation
The a/c clutch engages in all positions except for OFF, Vent, and Floor.
Old Jul 1, 2003 | 04:53 AM
oshoguno's Avatar
oshoguno
A/C operation
Thanks for the info guys.
crapshootersteve
Jan 6, 2023 12:41 PM
claycomotrucks1991
May 27, 2009 07:04 PM
dynamitedan
21
Aug 18, 2007 09:45 AM
TMCALLISTER
Modular V10 (6.8l)
Jul 23, 2003 03:13 PM
TMCALLISTER
Jul 21, 2003 10:00 PM
