Starter Hanging
Old Jun 2, 2007 | 11:08 AM
bigorr's Avatar
bigorr
Starter Hanging
1987 f150Starter is hanging turn switch off sitll engaging. I replaced the relay on firewall still wont help drained battery turning over. Can someone help.
Old Jun 2, 2007 | 11:13 AM
boggerted's Avatar
boggerted
Your solenoid is probably sticking. You can try hitting it with something to see if that is the probloem, but you cant really positively rule it out using that method. I would just replace the solenoid, theyre cheap enough. That happened on my 1984 F350 and the solenoid fixed it. Beware though, that if it continues to crank like that, you are still dumping fuel into the car without spark, so it can cause a dangerous situation.
Old Jun 3, 2007 | 09:26 AM
Phillip Guidry's Avatar
Phillip Guidry
Is the truck an EFI ? If so, you MUST buy a solenoid that has a diode built into it.
Old Jun 14, 2007 | 07:48 AM
bigorr's Avatar
bigorr
I pulled my battery and gave it a full charge. When I replaced it the truck started right up no problem I then let it sit a short time and the starter got hung again could it be a bad cell in the battery causing this?
Old Jun 14, 2007 | 08:06 AM
Bruce R Leech's Avatar
Bruce R Leech
check the battery. and check the starter solenoid and Bendix. also check the wire that goes to the s terminal on the realy that you replaced to See that it is deactivating with the key off.
Old Jun 14, 2007 | 11:51 AM
bigorr's Avatar
bigorr
How do I do this. My Dad said to pull the small single wire off the selenoid?
Old Jun 14, 2007 | 12:00 PM
Bruce R Leech
that would be the one marked with the letter s under the post. you need to look real hard it is molded in to the black plastic. I dont know if all of the aftermarket ones are marked the same . but that wire should only be hot while the key is in the start position. if it remains hot in the run or off position then you need to check the ignition switch lock mechanisms.
Old Jun 14, 2007 | 12:05 PM
bigorr's Avatar
bigorr
could it be a weak battery causing the selenoid to close?
Old Jun 14, 2007 | 12:07 PM
hogdogs's Avatar
hogdogs
Had to in the column on my taurus because of the same thing... Is this a weakness on many ford systems?
Brent
Old Jun 14, 2007 | 06:37 PM
netscaner's Avatar
netscaner
A weak battery won't cause a solenoid to close, but when you hit the ignition it can do a soft close which doesn't accurately seat, which alows it to stick.
Old Jun 15, 2007 | 09:21 AM
bigorr's Avatar
bigorr
Bottom line could it be the old battery in my truck? I worked great when i first took it off charge then it started doing it again
hotrodharley84
May 21, 2013 12:17 PM
DENNIS VANSLYKE
1997 - 2003 F150
Jul 24, 2011 09:47 PM
DENNIS VANSLYKE
1997 - 2003 F150
Jul 24, 2011 09:17 AM
sanpedro65
Jul 8, 2010 10:28 AM
cbfomoco
Oct 23, 2006 10:18 PM
