anyone had the starter hang up upon stating? I have replaced solenoid,starter and cables,From napa so they a generally good parts. Been 6 months, other day stated it hung up again this time I had to disconnect the battery, came home 4 days later started right up. any help would be appreciated. It is in a f-100 1974 with a 1975 390,c6. thanks sanpedro65
Reason: no engine size or year,
Sometimes if the battery is low, or the grounds are bad, or some other problem with the cables, the voltage is too low, and the current draw is too high, and the solenoid contacts weld themselves together, keeping the starter engaged.
With a good volt meter, preferably a digital one, check the voltage at the battery and report back. Then, with the volt meter still connected to the battery, start it and see what the voltage drops to as it's cranking.
Then, connect the + side of the volt meter to the cable AT THE STARTER, and the - side of the volt meter to the battery (-) and again, start it and see what the voltage drops to.
I had the exact same problem, turned out the battery was just good enough to crank it over, but the voltage was too low, causing excessive current through the solenoid and the contacts would weld themselves together.
Hitting the solenoid made it stop cranking. Does that work for you?
