Dyno Graphs
Old May 31, 2007 | 12:40 PM
Hiflyer746's Avatar
Hiflyer746
Dyno Graphs
Here are the Graphs for my 5 dyno runs the other day. Notice how they all look itentical. Those with lots of dyno experience. . . especially with the 7.3, tell me what you think. Thanks.
tim
KEY:
Max is my Hypermax Chip
DP 1: stock
DP 5: Economy
DP 6: race
DP 7: smoke
Old May 31, 2007 | 01:27 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
There's not much wrong with the torque curve, although it does fall off a little faster than most PSD's I've seen. Looks more like a Cummins curve.
I have no explanation for how the stock setting could be producing virtually the same power as the HP settings. I would guess you are running out of HPO on top...but even that doesn't explain why the different settings ramp up at the same rate.
Old May 31, 2007 | 01:30 PM
cookie88's Avatar
cookie88
FTE Emeritus
What kind of shape is your clutch in? If it's smoked and slipping real bad it might be the reason. It could also explain why your HP/TQ readings are so low compared to your sig line.
Old May 31, 2007 | 05:43 PM
Hiflyer746's Avatar
Hiflyer746
clutch
The clutch is fine. Every once in a while under super high load at high speeds I'll see it slip a very little. . . but there is no way it was slipping on the dyno.
Tim
Old May 31, 2007 | 06:05 PM
cookie88's Avatar
cookie88
FTE Emeritus
What are you running for a fuel pump? Running out of #2 up top?
Old May 31, 2007 | 10:19 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Once you measure fuel pressure, and check to see that is good, and once you get the autoenginuity you can monitor the essentials. Do you set a SES light when you do the dyno?
Old May 31, 2007 | 11:50 PM
Hiflyer746's Avatar
Hiflyer746
ses
yeah i havn't seen the SES light in a while. And it didn't show up on the dyno. I'm thinking i might have the wrong ICP in it. I broke the connector off while doing the turbos, i went to IH to get a new one, and there was confusion about which one it was. i didn't have the serial number or the base of the old one to get the part number. So we guessed off of the year. however, the new one was a little different. the body was larger. it took a larger wrench to install it. I'll have to check on that. But that and fuel pump pressure are my two biggest issues along with the HPOP itself. Kris for some reason i don't think that it would do any good to start the dyno at a higher rpm. I believe that its not measuriing exactly from speed A to B, but rather and infinite number of increments in between. The Dyno knows that through the RPM range that it will accelerate faster or slower at some points than others. . . its not a single average, but many averages.
Tim
Old May 31, 2007 | 11:53 PM
Hiflyer746's Avatar
Hiflyer746
fuel pump
Scott, the Fuel pump is an Aeromotive marine pump that comes with Dieselsites CPRx kit. . . more than adequete, but who knows. . . something could be causing an issue there too.
Tim
weber6point2
6.2L V8
Jan 26, 2014 06:18 PM
theenforcer
Jul 27, 2012 08:50 AM
jasfaa
Oct 24, 2004 01:49 PM
FarmLaw
Dec 30, 2003 11:07 AM
Ratsmoker
71
Jul 18, 2003 07:16 AM
