Get yer FE dynoed here....
Old Mar 27, 2003 | 05:37 PM
Ratsmoker's Avatar
Ratsmoker
I've been out for a while due to a heavy workload here in Korea. I have seen a couple requests for having a dyno graph posted. As I am off for the next few days, I will post as many graphs as you like. Have all the requests in by saturday night.
Here is what I must have....
1) Bore X Stroke
2) Head info: (Casting Number, any port work done etc..) Flow numbers are the best.
3) Carb Size
4) What intake you have
5) Compression Ratio
6) What kind of exhaust you have (headers, mufflers etc...)
7) Cam Specs: (Accuracy is very important)
Valve events (preferably @.050 but not necessary)and lift
or
Duration, lift, LobeCenter Angle and intake centerline
readings at .050 seem to be more accurate but make sure you say advertised duration or .050 duration.
Please do not post anything without this info. Guessing on cam specs could make the graph very inaccurate and kind of defeats the purpose.
Old Mar 27, 2003 | 06:07 PM
Ratsmoker's Avatar
Ratsmoker
Here is your's Biohazard...
Old Mar 27, 2003 | 06:11 PM
Jsbiohazard's Avatar
Jsbiohazard
Thanks Ratsmoker!!!!
Old Mar 27, 2003 | 07:24 PM
FE427TP's Avatar
FE427TP
1) Bore X Stroke
4.080*3.981
Edelbrocks.... .100=88/64 .200=153/113 .300=195/148 .400=233/171 .500=265/183 .600=270/200 per their website
3) Carb Size
750-780CFM
Blue thunder
10.25:1
1 3/4"*31" primary 3" collector 3" exhaust with X pipe
Valve Adjustment= .022
pre lash lift= .580
post last lift= .5588
Duration at .015= 282*
Valve timing at .015=
intake open= 35 Close= 67
exhaust open= 75 Close= 27
intake centerline 106*
.050 duration 236
lobe seperation 110
Old Mar 27, 2003 | 08:14 PM
Ratsmoker's Avatar
Ratsmoker
Now that is what I mean when I say specs! Can't get any better than that for the intended purpose anyway. BTW, I like that cam a whole lot. Check out the torque.
Old Mar 27, 2003 | 08:36 PM
rusty70f100's Avatar
rusty70f100
Heres mine:
1. 4.083 x 3.78
2. C7AE-A heads, mild port work (mostly gasket matching), no flow numbers available
3. <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">Holley</a></a> 600 vacuum secondary
4. Edelbrock Performer RPM
5. 10:1 compression ratio
6. Hedman Hedders
7. Cam info: Events at .050:
Open Close
Intake 1°BTDC 35°ABDC
Exhaust 51°BBDC 3°ATDC
Lift at valve:
Intake: .533"
Exhaust: .563"
Desktop Dyno graph would be highly appreciated!
Old Mar 27, 2003 | 10:55 PM
FrayedSanity's Avatar
FrayedSanity
Ok, here we go:
1) 4.080 x 3.78
2) C7AE-A - with CJ sized exhaust valves (1.665) no porting. 69.9 cc's nominal; cc'd out to 69.6-70.2 cc's across the range of all 8 cylinders;
3) Edelbrock 600 (#1406) - no mods
4) Performer <a href="http://www.motorhaven.com/">390 </a>intake - no mods
5) 9.5:1 CR estimated
6) 1 3/4" primary headers 3" collector > FlowMaster 50's (2 1/2" I think!)
7) Crower .270HDP specs are off the cam card!
CAM DEGREED AT .050" LIFT
Open/close:
INTAKE; -3*/36* ATDC
EXHAUST; 46*/-6* BTDC
LOBE SEPERATION - 112*
duration @ .050
INTAKE; 210*
EXHAUST; 220*
lobe lift
INTAKE; .280
EXHAUST; .296
lobe intake centerline
108*
show me what I got, and thanks!!
Old Mar 27, 2003 | 11:03 PM
stephenw's Avatar
stephenw
Hi Rat,
I have run my <a href="http://www.motorhaven.com/">410 </a>on Perf Trend's Engine Analyzer, so curious how they compare.
1. Bore 4.09" Stroke 3.984"
2. Heads Edelbrock 6007
In/Ex PortVol 170/125cc; from Stan Weiss website: Flows(cfm): @.100" 83/64, .200 153/113, .300 195/144, .400 233/171, .500 265/183, .600 270/200, Average 223/163
3. Carb <a href="http://www.motorhaven.com/">Holley</a> Truck Avenger 670
4. Intake Edelbrock Performer
5. Compression Ratio 9.0:1
6. Exhaust Sanderson F<a href="http://www.motorhaven.com/">390 </a>Shorties with 2 1/2" Flowmaster 50's
7. Cam Crane 343941 Hydraulic .050" Events Intake/Exhaust 216* .533" / 228* .563"
Timing: Intake Open 1* Close 35* Exhaust Open 51* Close -3*
112* lobe separation angle
Really appreciate your willingness to crank these out!
Steve
Old Mar 28, 2003 | 12:09 AM
Ratsmoker's Avatar
Ratsmoker
Your username is in the graph at the bottom.
Old Mar 28, 2003 | 06:03 AM
jowilker's Avatar
jowilker
Sean, I'll bet you'll have fun now.
Old Mar 28, 2003 | 12:20 PM
FrayedSanity
Cool, very very cool! Thanks rat!
Old Mar 28, 2003 | 03:48 PM
rusty70f100
Woohoo! Thanks man!
Old Mar 28, 2003 | 04:24 PM
Andysutt's Avatar
Andysutt
That's all you boys got?
come on now... we need more than 400 ft lb or torgue :P
Nice stats tho
Old Mar 28, 2003 | 06:13 PM
FE427TP's Avatar
FE427TP
Nice stats tho
Mine was coming through as a Red X how's this for more than 400?
Old Mar 28, 2003 | 11:24 PM
Andysutt's Avatar
Andysutt
Looks good. Care to send me a parts list, so I can go by that to build my 390?
