big problem
Old May 26, 2007 | 08:24 PM
cwall4x4's Avatar
cwall4x4
big problem
early 1999 (4/98) f350 4x4
here is my problem. i just got done driving about 60 miles (st. pete fl. to sarasota fl.) doing about 75-80 mph on the highway. I get off the highway and start driving in town i almost get home and i push my gas peddle to pass someone and nothing, it drops into the lower gear like its going to pass but it would not rev. over 2200rpms i limp the last mile to the house. I then try to see how high I could get it to rev in park but again the highest is 2200 rpms. I have no mods other than a drop in K&N filter. Also the truck looks like it is blowing a blueish smoke out when I rev. it. I filled up right before I left (st. pete). It drove fine this morning when i went to st. pete. please help i need the truck for work. oh and there is no dummy lights coming on.
[img]depressed.gif[/img]
Old May 26, 2007 | 09:52 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE!!
IF you got a bad batch of fuel the filter could be plugged. That's where I'd start looking.
Also your fuel pump is inside the frame rail right under the drivers seat. Turn the key to run (but don't start it) and stick your head down there and make sure you can hear the pump running......It will cut off after 20 seconds.
Old May 27, 2007 | 12:07 AM
powerstroked162's Avatar
powerstroked162
bad batch of fuel is rare..... What about plugged EBP tube??
Cowboy Steve
Old May 27, 2007 | 12:24 AM
John311t's Avatar
John311t
Idk if a clogged EBP tube would do that, idont even have a tube for that since the hpop install when i bent it like a pretzel. Sounds like a fuel delivery problem, and with blue smoke, something with oil is involved.
Old May 27, 2007 | 01:19 AM
empiretc's Avatar
empiretc
That is so NOT TRUE!! It only took 2 times of me getting bad fuel to convince me to do the in-tank/prepump mods.
Both times, a relatively new filter looked like it had been dipped in tar!
Old May 27, 2007 | 04:04 AM
powerstroked162
Scratch that. A bad batch of fuel is somethin I dont see on my side of the mountain very often. My apologies to those that expierence this more often then I do.
Dosnt the EBP tube limit RPM's when its plugged?
Cowboy Steve
Old May 29, 2007 | 10:45 AM
cwall4x4's Avatar
cwall4x4
just to let you guys know it is my turbo. bearings are bad thank you for your time.
Old May 29, 2007 | 11:23 AM
rbaker6336's Avatar
rbaker6336
don't sound like turbo,just replaced mine and never had any blue smoke and seems strang to go all of a sudden
Old May 29, 2007 | 01:29 PM
fbilly420's Avatar
fbilly420
well if the bearings were bad in the turbo it is going to leak oil right in to the exhaust and possibly restrict the exhaust so blue smoke and bad turbo yes.
Old May 29, 2007 | 02:13 PM
Izzy351's Avatar
Izzy351
You might re-consider your choice of air filters when you get your new turbo, too. I've seen several dusted turbos with the K&N (both drop-in and conical).
Joe
Old May 29, 2007 | 02:17 PM
Kwikkordead's Avatar
Kwikkordead
The NAPA 6637 air filter is one of the best setups out there.
It will breath better than a K&N plus it will filter out all the dust, not just the chunks.
https://www.ford-trucks.com/forums/2...-my-truck.html
Old May 29, 2007 | 02:39 PM
rbaker6336's Avatar
rbaker6336
my bearing were loose enough that wheel rubbed,no smoke,could be wrong
Old May 31, 2007 | 06:28 PM
cwall4x4's Avatar
cwall4x4
ok new update. one of the bolts holting the turbine compresser on back out and wedged up against the wheel preventing it from moving. i am ordering a rebuild kit. for and also i have heard about the dusting of the motors. from another site and I already put a stocker back in there. at least until i can save the pennies for a air intake. thanks
Old May 31, 2007 | 08:48 PM
Izzy351's Avatar
Izzy351
6637 is only ~$40 and is usually free to install. Since you have an early 99, you'll have to buy some clamps and procure some type of adapter to fit the filter. Some here have done it with PVC, but I don't know exactly which pieces you might need. It's pretty easy, though...
Joe
Old May 31, 2007 | 10:16 PM
Benny2002's Avatar
Benny2002
Hey man, i live in bradenton and work in sarasota most of the time, if you need help with anything or some input, let me know
