cab lights wired to headlights
Old May 30, 2007 | 10:42 AM
abvoitik's Avatar
abvoitik
Cab lights wired to headlight switch
I just put some after market cab lights on...I'm wondering how to get the lead wire connected to the headlight switch so that when the headlights are on, the cab lights come on. I don't want to wire directly to a fuse post. The setup I have has each of the 5 lights attached to one lead wire which runs under the headliner, each light has it's own ground. I now have the lead wire ready for power just wondering if anyone has tapped into the headlight switch. If so, where is it and can I just splice into it? Thanks
Old May 30, 2007 | 10:57 AM
Izzy351's Avatar
Izzy351
I'm trying to imagine why you'd want cab lights on with the headlights...
But I'd tap into the line with an external relay so you don't put too much of a load on the switch/fuse. Five lights (depending on the wattage) could put a fair amount of added current through that circuit. The panel the headlight switch is mounted in can be pulled out, but I can't remember the exact procedure. I think you pop one side, then the other carefully with a screwdriver.
Joe
EDIT: Maybe you mean "Clearance" lights over the cab??
Old May 30, 2007 | 11:10 AM
SpringerPop's Avatar
SpringerPop
The procedure is:
Pop out the instrument panel closest to the door about three inches, push a little "lever" toward the middle of the truck that releases hooks on the body of the switch. Push out from behind. Release little red plastic safety clips and remove connectors.
If you haven't done this before, you could break some really expensive plastic...
Isn't the stock feed for the cab lights in the passenger's kick panel? There's a photo on here somewhere that ol' "Steel Trap" will remember. I'd think that would be the best place to pick up this power.
Kris?
Pop
Old May 30, 2007 | 04:29 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Solid brown wire on the back of the headlamp switch is the park lamp circuit.
Old May 30, 2007 | 10:29 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Why don't you want them to come on with the rest of the parking lights?
Old May 30, 2007 | 10:35 PM
abvoitik's Avatar
abvoitik
That would be fine also, how does that wire up? I'm just looking to wire them so I don't have to flick a switch specifically for the cab lights...
Old May 31, 2007 | 06:33 PM
cookie88's Avatar
cookie88
FTE Emeritus
See post #4
Old May 31, 2007 | 11:43 PM
abvoitik's Avatar
abvoitik
To clear it up, I have lights on top of the cab (clearance lights, roof lights, etc.) I would like them to come on with the headlights when I turn the headlights on....What color is that wire and is the "headlamp switch" just to the left of the steering wheel?
Old Jun 1, 2007 | 02:19 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yes.....the switch you use to turn on the headlights. Pop that switch out of the dash and tie your cab lights power wire into the brown wire coming out of the back of the switch. This will power your cab lights anytime the headlight switch is on.
Old Jun 1, 2007 | 03:13 PM
Izzy351's Avatar
Izzy351
I used the same wire to power the LEDs in my gauges -- works perfectly...
Joe
Old Jun 1, 2007 | 08:18 PM
badger2196's Avatar
badger2196
There is a connector for the factory fitted clearance lights behind the passenger kick panel. Remove the panel and it is pretty obvious where it is - just tap into that and the lights will operate just like the factory versions.
Old Mar 21, 2020 | 10:27 AM
Awingnut22's Avatar
Awingnut22
No factory plug for cab lights
I have an 08 F-150 base model and it doesn’t seem to have the factory plug for cab lights. I have checked the passenger and driver side. Any advice? If I have a fuse in-line with the lights I should be ok to splice into the switch directly
Old Mar 21, 2020 | 10:32 AM
Walleye Hunter's Avatar
Walleye Hunter
Welcome to FTE but you are in the '99-'03 diesel section, you'll be better off in the section dedicated to your model and year. Maybe a moderator can move this for you.
GaryKip
Feb 24, 2021 10:11 PM
scheer89
Electrical Systems/Wiring
Nov 30, 2008 09:04 PM
windsor94
Jul 28, 2008 11:32 PM
royharper
Feb 20, 2008 06:40 PM
_JK_
Apr 2, 2007 08:55 PM
