EBPV leak
Old May 30, 2007 | 12:58 AM
RubberDuck's Avatar
RubberDuck
EBPV leak
Guys, on this truck I bought to fix and sell, (flip truck) I found an oil leak coming from the EBPV rod hole. And it's pretty major. So my question is this..... Can I take the rod and plunger out with the turbo on the truck and re- oring it? What are your suggestions? I'm looking for an answer that I don't have to remove the turbo. Let me know what you think.
Old May 30, 2007 | 06:14 AM
bkcowboss's Avatar
bkcowboss
I know that tj pulled the rod out and welded the hole closed, when he comes on line he will be able to tell you.
Old May 30, 2007 | 07:26 AM
U.P. Builder's Avatar
U.P. Builder
Yes, you can just remove it and plug the holes. It's there to aid in warmup but I doubt you'll need it in Texas. Problem is where's all that oil coming from.
Old May 30, 2007 | 07:56 AM
RubberDuck's Avatar
RubberDuck
U.P. Yeah, warm up is not an issue here. The oil is coming from the rod hole. What size would a thread plug be? And what size tap? Welding the hole closed would be easy, but I don't have a machine that will weld aluminum.
Glide, your right. I need some input from Reverend Slither.
Old May 30, 2007 | 09:13 AM
tjbeggs's Avatar
tjbeggs
Cody the way mine is done it would require removing the turbo. jamming a pipe plug in there is a good option but I am not sure if it can be done with the pedestal in the truck. Check my webshots in the turbo album to see pics of my modded pedestal. sorry I am not more help.
Old May 30, 2007 | 12:52 PM
barebackjake's Avatar
barebackjake
1/4" npt plug works great i would imagine it could be done without too much of an issue to do in the truck
Old May 31, 2007 | 12:09 AM
RubberDuck's Avatar
RubberDuck
Yeah Tim, I was thinking you had one of those pedistals Rick modified. Is that correct? I'm actually gonna get him to do one of mine. And hey, you can't win them all!!!
Jake, that's what I needed to know, thanks brother. Now I just need a tap size.....but I can figure it out. Did you use any teflon tape, or just let the pipe tap do it's job?
Old May 31, 2007 | 12:54 PM
tjbeggs's Avatar
tjbeggs
Cody the Previous owner did this pedestal himself. not too bad of a job. looks pretty good and doesn't leak. Let us know how you make out.
Old May 31, 2007 | 10:45 PM
barebackjake
i used a 1/4npt tap and some loctite thread sealer and it never leaked, i just modded a superduty pedistal man thoose suck to do, the obs ones are much easier. if you do it yourself i would degrease the snot out before even trying to do it.
Old Jun 1, 2007 | 12:22 AM
RubberDuck's Avatar
RubberDuck
Thanks brother. By the way, where the hell you been? I ain't seen ya on here in a fort night. How's Stevenville? Smokey???LOL
Old Jun 1, 2007 | 07:27 AM
barebackjake
oh been crazy here workin a bunch with all the storms and puttin the van turbo in my truck, and everything else goin on. what about you?
JJD
Aug 1, 2016 11:01 AM
Franko72
28
Feb 26, 2016 03:04 PM
xbox73
May 5, 2014 06:47 PM
fleonardis
Mar 16, 2013 07:16 PM
Liquid10Rider
Dec 11, 2012 04:58 PM
