ebpv
ebpv
hey guys im in the process of replacing my up pipes and noticed that it looks like my ebpv is leaking. I got the reinstall kit for the turbo from clay and in it it has three orings labeld for the ebpv. Can i take the ebpv apart with out a new spring and rod and just reseal it? or are those three orings not for the inside of the valve?
AJ
AJ
You have o-rings for the solenoid on the pedestal and the piston cover. You will need a EBPV rebuild kit. Clay sells them too.
This is the kit 99-03 Turbo Pedestal EBPV Rebuild Kit
the kit that comes with the turbo reinstall kit says turbo reintstall EBPV orings, then lists EBPV backplate oring (1) and solinoid orings (2)
I understand the backplate oring but not to sure about the other 2. also can i reuse the old rod assy? I actually cant order anything new since my truck is in my jobs shop and I cant have it sitting come monday.
thos O-rings are hard to find. although I am told they rarley leak. just thought of replacing them since I had it all apart. but alas, it will not happen cause that measns I would have to wait for parts again.
dealer dont even have the o-rings unless you buy the whole part $300+
I have both pedestal and turbo rebuilt kit.
unless those little orings are hiding in anohter place in the little baggy I do no have them in my turbo rebuild kit. I presume we mean the same thing when you say reinstall kit?
no matter cause I can't wait any longer to order and ship parts. I am ready to put it all back together. if it leaks there I wont see it cause I have a van and look from the back side
PJ-Hunter
06-24-2013 01:53 PM
dpslusser
09-17-2012 06:55 PM
cjcocn
16
05-17-2009 04:11 PM
