1966 - 1977 Early Broncos
New carb linkage problem
Old May 27, 2007 | 04:29 PM
v8xploder's Avatar
v8xploder
I just put on an edelbrock performer manifold and the holley truckavenger 670 on the 351W. The stock throttle cable linkage doesnt quite work. I was wondering what others have done to remedy this or make it work.
Old May 28, 2007 | 07:25 AM
ken75ranger's Avatar
ken75ranger
What's the problem? Not long enough? Too tall? I have about 4 turns left on my linkage with a 5.0,stealth, 470 TA. If it's short you can go to a lokar throttle cable or you can try bending the bar at firewall.
Old May 28, 2007 | 10:36 AM
v8xploder's Avatar
v8xploder
The link that comes from the pivot that bolts to the manifold that goes to the carb is about 2 inches too short. Does the lokar cable replace the whole mechanical set up? That is something that I might be interested in. I tried messing with the stock linkage for an hour or so I couldnt seem to get it to work out.
Old May 28, 2007 | 06:21 PM
ken75ranger
You could put a longer piece of threaded rod on the pivot. The lokar cables replace the whole shootin' match. They go from the pedal to the carb and are cut to lenght. BC Bronco's stocks them. Maybe summit racing too.
http://bcbroncos.com/store/product_i...roducts_id=123
Old May 28, 2007 | 06:39 PM
v8xploder's Avatar
v8xploder
I am leaning towards that option. Where would a guy find a longer piece of threaded rod at? I was snooping around the parts stores and no one stocked much for that type of stuff. Is that a universal kit that you cut to length or comes cut to length?
Old May 28, 2007 | 10:34 PM
MMB's Avatar
MMB
JamesDuff.com used to carry a bellcrank and throttle rod kit for use with the 351W. I'm not running a 351 but on my 302 with AOD had to do away with the stock linkage that bolted to the intake manifold. Came off the firewall bellcrank with a threaded throttle rod assembly as found on many Ford trucks in the later 70's direct to the carb, much simpler than stock.
Old May 28, 2007 | 11:48 PM
McLeod's Avatar
McLeod
Here is how I made the throttle on my 351W work.
Got the parts at Summit:
http://store.summitracing.com/partde...0&autoview=sku
http://store.summitracing.com/egnsea...700+0&x=21&y=5
I had to shorten and add some threads to the linkage, as well as put an "S" bend in it.
Ken
Old May 29, 2007 | 11:25 PM
v8xploder's Avatar
v8xploder
I really like the way that turned out plus its much cheaper than an aftermarket cable assembly. How do those ends stay on the shaft though?
Old May 30, 2007 | 10:48 PM
McLeod's Avatar
McLeod
They thread on to the shaft, which makes them somewhat adjustable.
The ball joints bolt onto carb linkage and to bellcrank.
Old Jun 3, 2007 | 06:46 PM
v8xploder's Avatar
v8xploder
To cut the shaft at the right length did you have the carb at the idle position and the linkage in the Ilde position and cut to match?
Old Jun 3, 2007 | 10:45 PM
McLeod's Avatar
McLeod
Yes.
Just make sure that you don't cut it so short that you can't adjust the idle screw back out without the linkage being too short.
As a side note, make sure you have a good return spring. Nothing worse than a wide open throttle that won't return.
Ken
Old Jun 4, 2007 | 07:58 PM
v8xploder's Avatar
v8xploder
Well I got it all cut and tapped and it works perfectly, thanks for the great advice. Easy and cheap. O yea
mixup
May 30, 2014 03:14 AM
chaseon
Dec 14, 2013 04:14 PM
chaseon
Dec 11, 2013 08:25 PM
kmulholl
Mar 18, 2004 08:58 PM
Bill_s351
Jun 17, 2001 08:36 PM
