Injectors ????
Old May 22, 2007 | 09:52 AM
funzjb1's Avatar
funzjb1
Question Injectors ????
I was having some ARB's and gears installed in my truck and the guy installing them for me commented on the excessive black smoke out the exhaust and the rough idle it had . I have not noticed the problem because I have been driving the truck for 8 years and just used to it and I have almost 200,000 mi on it. My questions are .... 1- how can I check to see if the injectors are bad ????
2- Which type injector would be best to replace with if bad ??? I did plan to change them someday to stage 1 or 2 (really leaning toward the 2)
I hear alot about the Beans injectors, where can I get them?
I have an Edge tunner
4" exhaust
free flow intake
3" down pipe
shimmed FPR
5 spd
8" lift ( going to 12" to 14" have to make that myself)
39" tires (going to 41")
front and rear ARB's
5:13 gears
Old May 22, 2007 | 10:12 AM
skittlejr's Avatar
skittlejr
have you done the 10k mod? that would make a rough idle. with all those mods you should have some black smoke, maybe not at idle. check your air cleaner, if the engine is choked it will black smoke. i'll let someone else handle the injector upgrade question, not my forte. oh, it wouldn't cause black smoke, but since your troubleshooting you might check the fuel filter and the screen too if it hasn't been done in a while.
Old May 22, 2007 | 10:35 AM
Neal 97 250's Avatar
Neal 97 250
Here is bean's website they are nice and very helpful.
http://www.beansdieselperformance.com/
Feel free to call them I did.
Old May 22, 2007 | 12:09 PM
tjbeggs's Avatar
tjbeggs
The smoke is not a good indicator of injectors problems unless it is constant smoke even at idle. if its when your in the throttle it could be caused by your programmer and is normal. rough idle could be a number of things. With 200K the injectors could be worn out but its alot of money to just go on what this guy said. It requires some more diagnostic work.
Can you describe the smoke and when it does it, hot, cold, color, idleing, cruising, in the throttle?? all those types of things.
Old May 22, 2007 | 02:35 PM
powerstroked162's Avatar
powerstroked162
12" of lift..... My god son, thats a big rig.
Sounds feul related, But like Tj said drop some more info for us.
Cowboy Steve
Old May 22, 2007 | 08:42 PM
funzjb1's Avatar
funzjb1
What is the 10k mod???? and yes it smokes at idle more smell than black smoke, but majority of smoke is at cruise or full throttle it. screen been cleaned about 2 months ago
Old May 22, 2007 | 09:30 PM
tjbeggs's Avatar
tjbeggs
for the smoke try going to the stock programming. if its still smokes in the stock program you might have an issue. How much smoke are we talking? just a haze or noticeable black?
Old May 22, 2007 | 11:16 PM
funzjb1's Avatar
funzjb1
At Idle its just a haze but much smell to it, at cruise or throttle it is much black smoke. Enough to blacken the bumper corner and the exhaust tip alot
Old May 23, 2007 | 02:02 PM
powerstroked162
Drop that chip and see what happens. Sounds like some programming you gots makin ya smoke. Letus know what you come up with.
Cowboy Steve
Rizzo66_82
1966 - 1977 Early Broncos
Sep 18, 2010 08:14 PM
Allaa.Hassan
Jul 14, 2010 08:50 PM
hard puller
31
Jan 16, 2008 05:03 PM
tite4x4
1978 - 1996 Big Bronco
Mar 7, 2004 06:50 PM
Jrock909
Offroad & 4x4
Dec 23, 2003 07:28 PM
