high egt,s
Old Jan 2, 2008 | 08:31 PM
hard puller's Avatar
hard puller
Exclamation high egt,s
I have watched this site for 6 mounths and now my first post . As you can tell I can,t tipe to save a life!!!! here goe,s I have a 037.3 with 4" turbo back with no cold gate/ A htt 88mm turbo with 4" k&n cold air intake / edge with attude / and two pyro's 1 befor and 1 after. the ploblem is I cant pull my 5 whl. with out droping gears the trans is auto and rear gears are413. I will get to over 1300 be for I evan get started. Even when not loaded it will run 700-1000 on a small grade 1/4 mile or so. (help!!!!!) Darn!!!! the truck is A 03-7.3 /6" lift with 35s and arb's frount and rear.....<S. p and front arb?s 35?s lift 6? cab crew 4x4 f-250 a it?s oh! (HELP!!!!!!!) egt?s 700-900 is it fwy the on truck emty an have I win Even rear.!!<>
Old Jan 2, 2008 | 08:51 PM
DCSpecial's Avatar
DCSpecial
How heavy is the trailer?
Big tires, heavy trailer= high EGTs with stock 3.73 gearing .
Also, not sure how hot those Edges run.....what setting are you in?
Most 7.3 owners prefer a custom tuned multi position chip (DI, TS, DP, BTS, Elite, TW, etc..).
Old Jan 2, 2008 | 08:57 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
well you sure you dont have boost leak, that 700-1000 sounds little much , i would drop the K&N and look for Soot buildup aroud up pipes and exhaust, downpipe, and the baby Butt in the back of the turbo, common problem if the turbo is replaced and not seated properly , will leak boost and jack up your EGT's
on EDIT
Welcome to the forum .... you will find all you answers here.
Old Jan 2, 2008 | 09:25 PM
hard puller
I have tryed the K&N off and no change!!!! the up pipe doe nuts have been replaced and the butt /up pipe manofold is not leaking !!!! the exhaust is not leaking!!!!
Old Jan 2, 2008 | 09:28 PM
PETE'S_6.0PSD
than try townig your trailer without the tuner remove it and see what your egts will go to on the same roads .
Old Jan 2, 2008 | 09:30 PM
hard puller
the trailor is about 1200 loaded and 9000 emty!!!! there are 5 settings on the edge and I have run from stock to tow-60hp and no change onthe egt"s but more hp!!!!-- the water temp is ok aswell as the trans!!!!
Old Jan 2, 2008 | 09:36 PM
DCSpecial's Avatar
DCSpecial
Now that I reread I see you have 4.10 gears?
That should make up for the 35s.
I'd think boost leak or the Edge as well.....
Old Jan 2, 2008 | 09:37 PM
hard puller
pete----I took the edge off complety and still had high egt"S . I gotr the truck with the larger turbo and the egt"s have been that high all the time!!!. I called htt turbo and they said that it must be In the fuel???????
Old Jan 2, 2008 | 09:44 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
What is the maximum boost you can see on a hard run in the extreme setting?
Old Jan 2, 2008 | 10:05 PM
hard puller
olny ran the #3 settinng --60hp but the bost is around 28-30!!!! It well pull hard but the egt"s jump to 1300= asap!!! at idaul it is 325 or so!!!
Old Jan 2, 2008 | 10:12 PM
PowerstrokeJunkie
Ok another thing- what do the post turbo EGT's say, and on average, what's their difference between the two when youre running the truck hard?
Old Jan 2, 2008 | 10:16 PM
hard puller
the post egt is 200 or so !!!! but if I am on a flat long road it will alll mose match???
Old Jan 2, 2008 | 10:21 PM
PowerstrokeJunkie
Well that makes sense. The turbo is basically a heat, pressure and velocity powered pump. When you have alot of pressure and velocity, the engine is making heat from the load. The turbo actually uses this heat to spool (and keep spooled) the turbo. The EGTs when the turbo is not "working" should almost be the same, but under a high load it should be alot less, 200-400* difference.
Something You could do is remove the intercooler, run boiling hot soapy water through it, and see how much oil you get out of it. The stock crankcase vent system runs it through the intake, and alot of it settles into the IC. That is a long shot, however worth a try, its free. Clean and dry it very well, and see if that changes anything. If you don't want to change the tuner ( Edge products is very base-level) i'd recommend a Spearco intercooler upgrade from blackwidowdiesel.com
Old Jan 2, 2008 | 10:22 PM
hard puller
the post egt is 200 or so lower !!!! but if I am on a flat long road it will alll most match???
Old Jan 2, 2008 | 10:30 PM
hard puller
Strokin!!!!! Ihave done the crankcase mod and washed out the cooler!!!!!!!! PS!!!! the thing eat"s FUELLLLLL!!!!!!!???? 8 or so to the gal.!!!
