1978 - 1996 Big Bronco
throttle kick down
Old Apr 15, 2000 | 03:41 PM
kevinguy@excite's Avatar
kevinguy@excite
throttle kick down
I have a 85 bronco with a 351 and it has a holley carb from ford, the throttle kick down vacuum hose is missing and i dont know where i should look to reinstall it......any awnsers
Old Apr 18, 2000 | 11:16 AM
Torky's Avatar
Torky
throttle kick down
I would think that the hose would connect to the vacuum modulator down on the trans, and run up to a source of intake manifold vacuum. Maybe somewhere towards back of manifold? Its purpose is to sense engine load, more load, throttle plate open wider, so less intake mainfold vacuum. The vacuum modulator has a rubber diaphram that converts that vac signal to mechanical motion.
If the hose has been gone for a while, I wonder if crud got into the modulator via the open hose port.
FYI, a vac modulator with a ripped diaphram will allow some trans fluid to get sucked up hose into engine, so suggest checking the inside of the hose at the trans after having it back on for a while. Modulator is easy to change, and not too expensive either. well, that about taps out my memory!
Old Apr 22, 2000 | 04:10 PM
Broncin's Avatar
Broncin
throttle kick down
larg3n
15
May 24, 2023 08:16 PM
stndrilla44
Nov 21, 2016 09:05 PM
tdimatteo
Escape & Escape Hybrid
Apr 7, 2015 12:22 AM
9wire
Nov 7, 2011 06:11 AM
07350PSD
6.4L Power Stroke Diesel
Feb 10, 2009 07:01 PM
