Ic cleaning
Old May 20, 2007 | 01:10 PM
mustang_gt_350's Avatar
mustang_gt_350
Ic cleaning
Just wondering what the best way of cleaning the inside of the IC to remove the oil when i do my CCV mod. I was thinking of using a light degreaser mixed with water and shaking it around and then flushing with fresh water to flush out all the cleaner, then standing it up to drain/dry for a few hours in the sun.
Old May 20, 2007 | 01:26 PM
Ed in Maine's Avatar
Ed in Maine
Sounds good, I would just get some simple green or greased lightening. It just seems like aluminum is hard to clean after anything gets on it.... so it may take a strong batch. We have some neat stuff up here called "Pink Stuff" that works good.
Old May 20, 2007 | 01:36 PM
mustang_gt_350
thanks i never thought about using simple green. I have a connection with some industrial grade degreaser. But i am affriad it will be to strong and hurt the alum. any thoughts? I'll have to see if i can find the manufatures name and contact them on the usage of the product on alum.
Old May 20, 2007 | 01:46 PM
Uzumati's Avatar
Uzumati
Add a shop vac on one end to help pull the air through and evaporate any moisture inside. Duct Tape will hold the vac hose to the IC nicely.
Old May 20, 2007 | 03:33 PM
Fat Diesel's Avatar
Fat Diesel
I used the hot air from my turbo to evaporate the oil. Made it easy since it's already hooked up.
Sorry couldn't resist. Most people I've read of doing the cleaning are disappointed in how little they get out.
Old May 20, 2007 | 06:00 PM
mustang_gt_350
i wanted to do it since i will be buying the truck used, and it will get me more familliar with the truck. Also i was thinking that if there was oil in the IC then it would have been enough to coat the inside all around and take away some ability to transfer heat as the oil coating would be 1 extra layer for the heat to transfer through. I'll admit tho it would probably be minimal, but i figured atleast then i know there isn't any inside it and it will make me feel better. lol
bakerbuilttracks
Jun 24, 2013 10:09 PM
77-250
Oct 19, 2010 09:27 PM
Izzy351
24
Mar 5, 2007 08:54 PM
hanzosblades
Jul 10, 2004 01:10 AM
sonnylowe
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Aug 4, 2002 12:31 PM
