I picked up my 2002 F250 7.3L PSD in mid-January with 60k on it. I've already begun the mods, as some of you may have read. I've already done the CCV mod, but I haven't removed the rest of the components to clean them yet. I plan on cleaning the I/C tubes & boots and removing the wrapping on the hot-side tube, but how do you all flush the I/C itself short of removing it? I imagine that there is a fair amount of oil in it. Also, do the orange CAC tubes under the Y-pipe need to be replaced or can they be cleaned and reinstalled?
Sorry if this is old-hat, but I've been reading & perusing the forum for several weeks and haven't seen anything directly related to these issues yet.
Joe
2002 7.3L F250 XLT CrewCab ShortBed 2WD
To flush the intercooler it needs to be removed. All 6 of the boots can be cleaned and replace but the oil degrades them over time so a new boot set while not required is good to do. http://www.dieselsite.com/index.asp?...rodID=547&HS=1
There's just no good way to flush it without removing it. Alan is correct, as usual. When you flush the IC, it needs to be able to stand on one end to let all of the water drain out. And, I'm not sure you could get all parts of it clean unless you were able to lay it flat.
Removal of the IC is not all that difficult though. It would take maybe 1-2 horus for a first timer.
Thanks fellas -- I'll get on it one of these weekends. I'm a little green on the SuperDuty, but I've done my fair share of wrenching on my other vehicles, plus I've been around diesels in the military for years...
I just wasn't looking forward to yanking the radiator & fan, plus draining the cooling system that was just serviced at the dealer when I bought it. They replaced the thermostat & temp sensor because the temp guage wasn't reading on my test drives. I know I can just capture all the coolant and dump it back in but I just hoping there might be a simpler way.
What do you guys use to flush it? Some kind of mineral spirits or something?
Joe
You don't need to do any of that. Remove the rubber tray clips that is between the grille and the crossmember, 4 bolts on each side of the crossmember, and then the crossmember pops out. The IC is right below that, and then that is all you need to remove it. No draining the radiator, fan removal etc.
Hey guys, this is just one more item on my to-do list, but how would you be sure of getting all the water out, or other de-greaser or solvent? Certainly would not want the engine to ingest.
Thanks, Bill
See?!?!?! I told you there was probably an easier way I hadn't thought of!!! Thanks for that -- I haven't even picked up a manual for it yet. I think that just bumped the intake cleaning job up a few weekends...
Joe
At 290k I had less than half a teaspoon of oil in the intercooler. It may be dirty but it wont be full of oil. I used simple green and flushed with hot water.
Okay -- well, "full" might be a little stronger than the word I'd use -- I figure since I'm going to be cleaning the tubes and replacing the boots, I might as well clean the I/C too.
Thanks for the info.
Joe
There may not be oil puddled up in the IC, but the insides of the tubes could still have a small film of oil on them that might hurt the performance of the IC by acting as an insulator.
Because I did the CCV bypass mod and added the Kwikfilter. Now that there's no source for oil getting into the intake path and nice airflow through the BAF (Big A$$ Filter), why bog it down with dirty, oily tubes & I/C?
Joe
Some of us that are PMS-infected have the urge to tinker with our trucks, even if there is really no benefit to doing it. It's just something to do to ease the PMS urge.
I'll buy that, good a reason as any. Now back to my first question about how to make sure all water or solvent is out of i/c ?
