Looking for suggestions from you guys. I need a way to have a controlled idle at about 900-1000 RPM, preferably at the flip of a switch. I know the 6.0L diesel has this in it's programming with a simple wire tap required, but being a diesel I doubt there's much of that circuitry that would apply here.
Basically, the alternator can't keep up with my headlights, parking lights, taillights, and driving/fog lights all at once. Anything above idle and it's fine, so I'd like to boost it up to 900-1000 RPM on command to fix the problem.
Anyone got suggestions on doing this? I'm all ears. Thanks.
I have thought about this because I want to build an idle controller also when I install a Power Inverter in my Ranger.
My thoughts: How about a vacuum switch with a series rotary adjustable valve? Tap into one of the vacuum lines, run it in the cab through the "analog" valve then through the pneumatic toggle switch. This way you can first adjust how high you want the idle with the rotary switch, and use the pneumatic toggle switch as the ON/OFF.
Wouldn't it be better to install a higher output alternator instead of burning more fuel to keep the lights on? Would the load due to a bigger alternator on the engine increase significantly to require the idle increase? Is this a reasonable approach? Pat
just put in a cable pull throttle. We have them in all of our farm trucks for when its cold. i can rev them up to 1500 and let them sit and warm up. you can even hide it in the glove box if you so chose
I'd go with a higher-output alternator myself.
I believe the '96 / '97 Explorer 4.0L has a factory 130 amp alternator that will work on Zach's Ranger, in place of the 95 amp factory alternator (pretty sure) he has in there now.
Thanks CMOS. I googled the topic and it is a common problem in like buses where high loads (lights, heater blowers, chair lifts) occur at normal idle conditions. The link showed for International buses they have a manual throttle button that jumps the idle speed up to some pre-set point. Another link showed a home grown version a guy installed on his jeep and it was basically a lawn mower cable to a lever attached to his stick shift like Matt described.
we have cable driven idle control that u pull and it manually pulls the trottle. it has no affect on normal driving (and i use it as cruise on our wheat trucks, illegal? hell i dont care)
Even with a high output ALT there is still the issue of pulley speed. A High OP ALT will still deliver minumal aperage at low idle speeds.
CMOS
I could be wrong, but I think the higher performance alternators, such as the 200A model listed in the link I posted above, come with a different-sized pulley to help address the lower-output-at-idle concern. I don't know that for sure so I'd probably email the vendor for more info if I were thinking about going that big. And I'd inquire about any wiring upgrade tips, as well.
Plus further to Rockledge's point and my initial thought, you may find that a higher output alternator can provide sufficiently more output at the idle conditions to meet your requirements.
Matt
Since Zach will use it only at idle, a properly "calibrated" stick positioned between the console and the foot pedal should be all he needs!!!
Could very well be. I've read about many people experiencing similar circumstances as Zach getting away with a simple 130A upgrade.
I don't think it would be a waste of money, in any event.
From what I read in the elctrical forum, a higher amperage alternator would actually put out lower amps at idle for whatever reason. That being said, this 130 amp alt from the Explorer might not be a bad idea, if of course, it will provide some sort of increase in power at idle.
How does this cable driven throttle boost work, and how do you get around the spring loaded return on the throttle plate?
It's a cable that attaches to the throttle, much like a throttle cable, but hand operated. Usually a black **** that you twist, tighten for more tension, or loosen for less tension. A red button will remove all tension and you are back to normal operation. And you can still have normal throttle operation, but only above your set idle.
I can't find anything to link, but you might find one at a truck or ag dealer.
Very interesting, I like it. I might have to look into that, doesn't seem as if it would be expensive or difficult to install either. Thanks for the idea.
I also was doing some talking with friends today, somebody suggested sending a fixed voltage signal to the IAC to maintain X RPM, but I'm not nearly good enough with electronics past sound systems to regulate voltage to that extreme.
