two steering boxes??
Old May 12, 2007 | 04:19 PM
SoArkSI's Avatar
SoArkSI
ok i have 2 f150 4x4's, one 77 and one 79, i believe the 77 was a late 77 with the same "y" link steering like the 78 and 79 and not the old "t" style. both of the steering boxes are the exact same look the same and will bolt up to either truck. my problem is that the 77 box has "RF-D6TW-3550-AA" and the 79 box has "RF-D7TC-3550-CA" stamped in to the back side of the box. i was wanting to use the sector shaft off of one and put in the other but was not sure if there was a difference in the boxes internally. If any is any one who can help me decifer these part #'s and let me know id really appreciate it. i also cannot get the lock nut and nut off of the top part to get the worm gear out off the housing to replace the seal and dust cap. it looks like i need a 4 pronged tool maybe to get this out??? the instructions i recieved with the seal kit are kinda vague... i guess i just need a little help!! thanks.
Old May 12, 2007 | 05:27 PM
Mil1ion's Avatar
Mil1ion
I'll be back
I need the SPA- .....number on the tag.
Old May 13, 2007 | 10:57 AM
SoArkSI's Avatar
SoArkSI
ok mil1ion i got your spa numbers. on the 77 the number is SPA BT and below it is 78A 31B. the 79 tag is SPA AX and below it says 76E 17B. the tags were kinda dirty so i hope that they are accurate.
Old May 13, 2007 | 02:40 PM
Mil1ion's Avatar
Mil1ion
The SPA AX was used on 77's before Y20001 and has a parts listing of number 81
The SPA-BT was used on 77's (from Y20001 - 1978) and has a parts listing of 83
I can post the onfo I see if you like ?
Old May 13, 2007 | 03:30 PM
SoArkSI's Avatar
SoArkSI
Yes that would be great. I might just use the right sectors back. I think the reason it was leaking in the first place is that my uncle (p. O.) put the inner seal and washer in backwards on the lower unit.
Old May 13, 2007 | 04:09 PM
Mil1ion's Avatar
Mil1ion
Old May 13, 2007 | 09:20 PM
SoArkSI's Avatar
SoArkSI
thats great! thanks for the help. does anyone know how to get the lock nut and nut off of the housing to get the work gear out of the upper housing to replace the seal and dust cap on the input side?
Old May 13, 2007 | 10:21 PM
Mil1ion's Avatar
Mil1ion
check on the autozone site...repair section
That new question is for the steering forum
Old May 14, 2007 | 06:00 AM
SoArkSI's Avatar
SoArkSI
alright, thanks! i wasnt for sure if it was steering or 73-79 particular.
Bulldog187th
Nov 7, 2016 12:43 PM
Carrot66
Apr 5, 2016 09:46 PM
mjunk1
Oct 10, 2015 05:16 PM
F250army45d
Jun 27, 2010 05:40 PM
Monteford
19
Jan 7, 2010 06:31 AM
