460 rad
Old Apr 26, 2007 | 12:39 PM
76fordo's Avatar
76fordo
460 rad
Just a question for all you guys running 460's out there, i rebuilt a 460 stock with an edelbrock intake and carb, just wondering if a stock 460 rad will keep it nice and cool. Also are they 2 or 3 core rads.
Old Apr 26, 2007 | 03:53 PM
stngh8r's Avatar
stngh8r
I dont see any reason why not. As long as it is in good shape (fins are clean and straight and the coolant passages are clean) and the fan is pulling like its supposed to.
The stock rad is pretty darn big, not sure the exact specs or anything though.
Old Apr 26, 2007 | 07:08 PM
Piffery1's Avatar
Piffery1
I put a 4-row core radiator in my '83 F350 with auto and A/C and it never overheats.
Old Apr 26, 2007 | 08:49 PM
Bear 45/70's Avatar
Bear 45/70
The 1983 and '84 460 trucks came with a 3 core radiator. All the others were 4 core. The trouble is that most after market replacement rads are 3 core and they are marginal for cooling at best.
Old Apr 26, 2007 | 09:17 PM
bhardy501's Avatar
bhardy501
I have a 3 core radiator on my 460 and it does fine. It wanted to get a little hot until I put on a fan shroud. The fan shroud made a big difference. The fan shroud is almost as important to cooling as the radiator itself.
Old Apr 26, 2007 | 09:40 PM
Bear 45/70's Avatar
Bear 45/70
Mine had the shroud with the 3 core and with my camper on the truck (4800 lbs) there was a slow overheat that you could make go away, even by backing the time down to 30° total advance. Was even worse when I added the boat or quad trailer. Swapped out the 3 core for the 4 core and poof, no more over heat. Oh yeah, the 3 core and been in and cleaned and check, so it was working right. Probably was why Ford used the 4 core up to 1983 then in 1985 went back to the 4 core.
Negrey
Aug 8, 2014 12:03 AM
Brushwacker
Jul 18, 2011 07:07 PM
HARLEY 97
Oct 10, 2009 09:53 AM
detmerdj
Dec 14, 2006 03:04 AM
merc460
Oct 7, 2002 10:41 PM
