Distributor timing advance question...
Old Apr 24, 2007 | 01:27 PM
Jrock909's Avatar
Jrock909
Guys for some reason I can't get my engine to ping, I have set the base timing on my truck to 20* with the spout out and let the computer take over and it's not pinging? Is it possible to have the balancer in wrong, surely that can't happen since there is a keyway which allows the balancer to go on only one way?
Old Apr 24, 2007 | 02:13 PM
Conanski's Avatar
Conanski
How are you testing for pinging? Just reving the motor in park is not how you do it, you have to drive it and put the motor under load after it's completely warmed up.
Old Apr 24, 2007 | 02:19 PM
Jrock909's Avatar
Jrock909
What a good load test for pinging, because I thought going up a hill would cause the truck to ping at 20* base lol!
Old Apr 24, 2007 | 09:00 PM
LxMan1's Avatar
LxMan1
Perhaps the outer ring has slipped on the balancer. My Mustang will ping at 13* unless I run 93 octane.
Old Apr 24, 2007 | 10:04 PM
Jrock909's Avatar
Jrock909
How can I find out if the balancers outer ring has slipped LX?
Old Apr 25, 2007 | 03:35 AM
darrin1999's Avatar
darrin1999
what year is the 302? if its one from the 70s then its probably around 8-1 compression and probably wont ping... compression has to be 8.5+ or really bad quench or really crappy heads to ping. my 1972 lincoln would ping at 7.6-1 compression and 10 degrees initial on 89 octane just from the exceedingly crappy head design
Jarryd
Feb 18, 2014 07:53 AM
duvail5
18
Sep 1, 2009 10:42 PM
LTCPipkin
Aerostar
Nov 17, 2008 04:56 PM
Jrock909
Apr 26, 2007 06:02 PM
factory594x4
13
Jun 11, 2006 03:13 PM
