pinging
Old Feb 17, 2014 | 06:23 PM
Jarryd's Avatar
Jarryd
pinging
How easy is it to recognize pinging. There are so many small noises I can't tell if it's pinging or engine noise.
Old Feb 17, 2014 | 07:22 PM
joey2fords's Avatar
joey2fords
the best description that i have heard to describe pinging is ... ball bearing rattling around inside a tin can ... no way can it be confused with the sound of a healthy running engine.
i would bet that a search on youtube will bring up someone displaying the sound of a pinging engine.
Old Feb 17, 2014 | 08:01 PM
Jarryd's Avatar
Jarryd
Finally found a good clip. I'm not pinging. Now I know what to watch for when I advance my timing.
Old Feb 17, 2014 | 08:27 PM
Jarryd's Avatar
Jarryd
I guess I asked because it sounds like a diesel sometimes under load and I thought it might be pinging. I think it's just what the 4.9 sounds like.
Old Feb 17, 2014 | 08:45 PM
88n94's Avatar
88n94
I would guess you have an exhaust leak.
Old Feb 17, 2014 | 08:47 PM
Jarryd's Avatar
Jarryd
That's possible, all my gaskets are factory. I have a vacuum leak too. I need to track it down. Oddly enough, I'm getting around 20 mpg.
Old Feb 17, 2014 | 09:01 PM
joey2fords's Avatar
joey2fords
diesel under load is another good description of pinging . a 4.9 does NOT sound like that when running right.
Old Feb 18, 2014 | 07:53 AM
Jarryd's Avatar
Jarryd
It only does it when it's cold and when I'm in a high gear at a low speed. Once I fix all the vacuum leaks I'll reassess what's going on.
yeahbuddy24
Nov 23, 2009 06:51 PM
1978Crew
Oct 9, 2007 08:44 AM
Ranger2000
General Automotive Discussion
Feb 13, 2004 03:13 PM
buckeyebronco
1978 - 1996 Big Bronco
Nov 20, 2003 10:05 AM
Raul
May 31, 2001 09:52 PM
