sbf distributor question
Old Apr 24, 2007 | 11:51 AM
black58's Avatar
black58
Hey guys, I have a 58 F100 with an 86 302 in it. I converted it to carb and bought an HEI distributor off eBay. The discription said it had a hardened gear and wouldn't work with earlier engines. The question I have is Is an 86 considered an early engine? Does anyone know if I can use one from a late seventies sbf. I have the distributor, ignition box and harness that connects the two. Although, I don't have the harness from the key to the box and would need a diagram. Thanks, John
Old Apr 24, 2007 | 12:12 PM
Conanski's Avatar
Conanski
It probably means it has a steel drive gear for a roller cam, instead of the bronze or cast gear found on flat tappet motors. The drive gear is pretty easy to change with a standard gear puller, however.
Old Apr 24, 2007 | 12:50 PM
black58's Avatar
black58
so I should be good. Worst case pull the old gear off the old distributor and put it on the new distibutor. Thanks, John
Old Apr 24, 2007 | 09:02 PM
LxMan1's Avatar
LxMan1
Does your engine have a hyd. roller cam? if so, the steel gear is fine. If it uses standard flat tappet lifters, then you need a cast gear.
Old Apr 25, 2007 | 05:19 AM
HemiEater's Avatar
HemiEater
what he said.........
Ruger86
17
Mar 24, 2021 05:49 PM
Wolffman
32
Apr 1, 2014 01:21 PM
black58
Apr 25, 2007 07:34 AM
obars
Apr 25, 2006 07:09 AM
