Engine oil temp.
Old Apr 24, 2007 | 08:59 AM
johnsjsj's Avatar
johnsjsj
Engine oil temp.
I have a 2002 PSD. Where is a good spot to put a temp. sensor for engine. Also a good spot for tranny (it does have a spot in the tranny pan which is a Mag-Hytec; will that give a good reading or should I go to some other place?)
Old Apr 24, 2007 | 07:21 PM
Uzumati's Avatar
Uzumati
Tranny - just above the pan driver side test port.
Oil - there is a plug near the oil filter - Come on JT post a pic for us
Old Apr 24, 2007 | 08:35 PM
ernesteugene's Avatar
ernesteugene
See my Post #6 here https://www.ford-trucks.com/forums/596286-2002-psd-gauges.html My oil temp sender is hooked to the white wire going to the top of the oil filter housing.
Old Apr 24, 2007 | 09:04 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Good pic and info Gene. I had forgotten about that post.
Old Apr 24, 2007 | 09:18 PM
jtharvey's Avatar
jtharvey
Well, here's one spot, where the gold canister is that's my oil pressure sending unit:
http://rides.webshots.com/photo/2035...89903167kFOzHV
But, there is also a plug on the oil filter houing that may be a better spot if you're not running a bypass filter like I am.
Edit: Gene's picture that he referenced is the one I'm referring to. I think it get's a better flow of oil for a more accurate and current reading.
Old Apr 25, 2007 | 07:13 AM
johnsjsj's Avatar
johnsjsj
Thanks for the help on the engine temp. Now how about where to sense the tranny temp. As I stated above there is a plug in the pan (MAG-HYTEC PAN) or is there a better spot to get an accurate reading?
THANKS
Old Apr 25, 2007 | 07:59 AM
aklim's Avatar
aklim
I'd go with where everyone tells you. That way, when you say I have a temp of XXX, we can compare apples to apples.
Old Apr 25, 2007 | 10:07 AM
BobbyDiesel71's Avatar
BobbyDiesel71
We have the same truck LOL
I installed the oil temp sender using one of the ports next to the oil filter housing, there are two ports plugged.(these are used by the guys running the OIL GUARD system) I installed the trans temp sender on the designated MAG HYTEC tranny pan.
good luck!
Old Apr 25, 2007 | 01:31 PM
15 and 92 Dad's Avatar
15 and 92 Dad
I have a 2000 F250, I removed the pan, drilled hole and tig welded a bung in with a 1/4 NPT. I dont think I could get a more accurate reading than were its at. The plus side, I chagend the tranny filter and it need an oil change anyway, I average 195-200* pulling 10,000 lb toy hauler!
Richard
kenny nunez
Ford Truck Parts for Sale
Aug 8, 2014 03:19 PM
WestxSRT10
Nov 14, 2008 05:15 PM
Gage2502
Apr 16, 2008 11:46 PM
ReAX
Jan 11, 2007 10:12 PM
Fishin-Technician
Apr 17, 2003 12:01 PM
