Got the codes
Old Apr 23, 2007 | 01:45 PM
emain879's Avatar
emain879
Got the codes
MY edge is throwing p1748 Transmission Fluid Temp sensor p1728 and Tranny slip any help whats wrong?
Old Apr 24, 2007 | 12:37 PM
tjbeggs's Avatar
tjbeggs
the 1748 comes up as a EPC malfunction in all the list I can find
the 1728 says either a solenoid malfunction or mechanical problem
Either one is not good! Does the tranny seem to slip at all? I am not very good at diagnosing trannies. maybe somebody else has a good idea. How does the fluid look and smell? if it dark and smells burnt it can't hurt to change the fluid.
Old Apr 24, 2007 | 05:09 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Sounds like it got hot. Try flushing the tranny fluid and clearing the codes.
Old Apr 24, 2007 | 06:02 PM
tjbeggs's Avatar
tjbeggs
um where did my post go???? I responded to this thread today but now its gone??
did anybody see my post? is it hiding again??!!!
the 1728 says a solenoid or mechanical malfunction
the 1748 states a different problems something like EPC issue. I don't know what that is
I agree with scott. clear the codes and change the fluid and filter
Old Apr 24, 2007 | 06:45 PM
Cuda_jim's Avatar
Cuda_jim
TJ you didn't loose your post, this is the 2nd or 3rd time it's been posted.
EPC= Electronic Pressure Control. Sound like stuck solenoids in the pan, probably from overheating.
Old Apr 24, 2007 | 07:34 PM
tjbeggs's Avatar
tjbeggs
ah thank goodness I thought we had a post gobblin running around trying to sabotage FTE!
maybe its a test for being consistant!!?? did I pass?
Old Apr 24, 2007 | 08:59 PM
cookie88's Avatar
cookie88
FTE Emeritus
Found it. , put it back where it belongs.
Old Apr 24, 2007 | 09:01 PM
tjbeggs's Avatar
tjbeggs
thanks Scott. Jim was right though there were two identical posts. Well maybe you figured that out and just merged them. Either way thanks!
Old Apr 24, 2007 | 09:09 PM
cookie88's Avatar
cookie88
FTE Emeritus
No problemo. Glad I could help.
awillo0406
20
May 7, 2013 02:58 PM
MiamiPSD
Feb 6, 2013 05:08 PM
sneak
Jan 24, 2006 09:09 PM
Ultramagdan
1997 - 2003 F150
13
Jun 27, 2005 10:10 PM
