codes anybody?
Old Jan 23, 2006 | 12:03 PM
sneak's Avatar
sneak
codes anybody?
I am in a hury to get out of the office, not for answers....
po344
p1248
p0470
p1211
p1280
p0603
p0720
Old Jan 23, 2006 | 12:18 PM
CAT_man_963's Avatar
CAT_man_963
From Steve Baz website...
po344 - 0344 CMP Camshaft pos sensor ckt intermittent Incorrect number of CMP transition counts Harness routing, charging ckt, sensor, int ckt, improper gap
p1248 - (didn't see this one)??
p0470 - 0470 EBP Exhst press sensor ckt malfnct (96 MY) No-start or crank mode Biased sensor, open signal return
p1211 - 1211* IPR ICP pressure above/below desired Continuous and KOER on-demand test IPR valve failed, stuck, or shorted to ground
p1280 - 1280* ICP ICP circuit out of range low Uses inferred ICP strategy Open/grounded circuit, biased sensor, PCM
p0603 - 0603 PCED Powertrain Control Module KAM error No historical faults output during a KOEO test Open PCM pin, disconnected B+, faulty PCM
p0720 - (Didn't see this code either)??
Old Jan 23, 2006 | 12:26 PM
mech2161's Avatar
mech2161
po344 CMP sensor circuit intermittent
p1248 turbo boost not detected
p0470 exhaust back pressure sensoe circuit malf.
p1211 ICP not controllable pressure above/below desired
p1280 ICP out of range low
p0603 internal control module KAM error
p0720 OSS sensor circuit malf.
Here are the code descriptions
Old Jan 23, 2006 | 09:31 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
http://www.freeautoadvice.com/diesel/pscodes.html
Old Jan 23, 2006 | 09:35 PM
CAT_man_963
Awesome Cookie - that's now a new bookmarked page on the top of my "Diesel" list!!
Old Jan 24, 2006 | 04:35 PM
sneak's Avatar
sneak
OK, thank you all verry much for helping, and thanks for the new bookmark!
Old Jan 24, 2006 | 05:35 PM
Kwikkordead's Avatar
Kwikkordead
Same here, that's a great page.
Old Jan 24, 2006 | 09:09 PM
cookie88's Avatar
cookie88
FTE Emeritus
I thought you guys might like that. It is soooo much faster than going to the book every time you need to know a code.
awillo0406
20
May 7, 2013 02:58 PM
MiamiPSD
Feb 6, 2013 05:08 PM
rado
Jul 2, 2011 01:40 PM
Ultramagdan
1997 - 2003 F150
13
Jun 27, 2005 10:10 PM
