gear change w/e40d?
Old Apr 21, 2007 | 10:17 PM
ger-mikes's Avatar
ger-mikes
gear change w/e40d?
I have a 92 f150 2wd w 4.9 six. It has 308 gears, want to put in 373's what do I need to do so e4od transmission operates correctly, I just had her rebuilt and upgraded! Thanks!
Old Apr 22, 2007 | 08:37 AM
Cuda_jim's Avatar
Cuda_jim
Your tranny will operate OK with either axle ratio IMO. The 373 gears will be a little easier on the tranny, especially if you are pulling big loads. The 308 will get better milage at e-way speeds but make s the truck a dog. You might be able to get an entire axle from a junk yard for the cost of just changing gear ratios. If you buy a new ring & pinion + installation kit you are looking at 300-500$ new + labor.
Old Apr 27, 2007 | 11:05 PM
ger-mikes's Avatar
ger-mikes
good advice Thanks cudajim. I'lll call a few yards see what they have available! Thanks Again!!!!
Sparkydm
Oct 16, 2010 08:26 AM
deere81
Nov 21, 2009 08:23 AM
Tren
1978 - 1996 Big Bronco
Aug 26, 2009 04:37 AM
Gr8ride
30
Dec 4, 2002 07:51 AM
Pastmaster
May 13, 2001 11:33 PM
