Ditributor swap
Old Apr 17, 2007 | 12:10 PM
drof46's Avatar
drof46
Ditributor swap
I have a 64 with a 223. Anyone switch from points to the non-point system? Does it increase power? Also I may have a bad vacume advance, does this matter if I switch to a non-point set-up?
Websites with the product would be helpful if you have them. Thanks
drof46
Old Apr 17, 2007 | 12:53 PM
tbm3fan's Avatar
tbm3fan
All my Fords have the Pertronix system in them. Advantages are no more screwing around with points and dwell. Seems to be easier to fire up the cars. Increase power I would say no to. All you are really doing with the Pertronix I is introducing greater reliability into your ignition system. The Pertronix II does have a different module which does more assessment of your spark than the original Pertronix. To take advantage of it you need to use a higher output coil and wire the Pertronix to a full 12 volts off the ignition switch, bypassing the standard ignition resistor wire. That you can leave to the coil as though nothing changed except the extra wire now going straight to the red wire from the Pertronix II. Some say this system increases power but it is all relative. At least you get a more efficient spark. Both systems drop right into your existing distributor if it is in good enough shape to use.
As for your vacuum advance it would be a very good idea to maintain it in a functioning state. Your engine will run much better and be more fuel efficient at cruising speeds with it working and adjusted correctly.
PROSTOCK's Avatar
PROSTOCK
Admittedly I am not familiar w/ the 223, but you can easily swap the "guts" from any V8 Duraspark distributor into a points V8 distributor. Whether that same trick holds true for you 223, I dunno, but I'd think so. You'd need to find a 6-banger Duraspark dist. and take a gander.
Old Apr 17, 2007 | 03:42 PM
64fordf100292's Avatar
64fordf100292
fellow 223 owner
hey felow 223 owner. i will probably get in trouble for this but ther is a website specifically for the ford 6 cylinders. the name of it is fordsix.com lots of info. and as far as your question. if you have a 64 or newer 223, you can take a duraspark dizzy from a 240 or 300 6 cylinder, hone out your 223 gear to fit the 240/300 and swap the gears on the distributor and the 240/300 dizzy drops right in. the reason i say 64 or newer is because of the oil pump drive shaft. 64 and later used a 5/16" oil pump shaft. the pre-64 223 had a 1/4" if I understand correctly. now, there is also good news. you can take a 64 and newer oil pimp with the 5/16" shaft and swap it for the 1/4". then you have the right shaft. and prolly better oil pressure(cause of the new pump). hope this helps. If the website got blocked. drop me a pm. i'll get ya taken care off.
Old Apr 17, 2007 | 03:43 PM
64fordf100292
fellow 223 owner
also, if ya swap in the 240/300 dizzy, you get rid of that damn load-o-matic too. kill two birds with one stone.
Old Apr 17, 2007 | 06:36 PM
Tedster9's Avatar
Tedster9
Is there anything wrong with the Pertronix that would benefit going through the trouble of installing Duraspark or later dizzies? I installed the Pertronix II in about 5 minutes and haven't had a problem at all. I would say it definitely runs better at all RPMs and speeds. It's always started right up instantly, but now it takes just a millisecond of starter engage to pop off. It seems like a good product from a good company. I do keep points and condensor in the glovebox just in case.
Old Apr 18, 2007 | 11:40 AM
drof46's Avatar
drof46
Thanks for the info on using a later model distributor. I have two distributors from 64's and both are in decent shape, but I have always looked around for another option. Sounds like the Petronix may be the simplest way for now and I could try to hone out the other distrubtor I have as time permits.
thanks,
drof46
Old Apr 19, 2007 | 01:22 PM
hiball3985's Avatar
hiball3985
be sure your vacuum advance is working, its critical on a 223, its the only advance you have, theres no centrifical advance in a 223 dist..with out it you'll have a great loss of power and heating and few enconomy problems
Old Apr 19, 2007 | 01:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C0DF-12370-A .. Vacuum Advance (Motorcraft DD-12)~Fits: 1960/64 223 I-6 // 1960/63: 144/170 I-6 [Falcon/Comet/Fairlane]~[there's no mention in the parts catalog of a Load-O-Matic dizzy in 1964].
Old Apr 19, 2007 | 06:02 PM
seetwisted's Avatar
seetwisted
Long Live the 223!!! mine lived long and hard. If...I still had one,I think I'd look at Pertronix or something similar. LONG LIVE the SIXER!
Old Apr 19, 2007 | 06:06 PM
oldtrapper's Avatar
oldtrapper
I did a little research and went with the Duraspark on both my 66s. About 3 ys ago and I know the Petrox seems to be ok but with all stock parts ez to get if you ever need anything you should be ok. I can still reach in and just bump the starter and the old rascal start up immediately making the ground rumble with the headers barking. Only 2 wires to splice in. I have no problems with the system.
My 2 cents.
Old Trapper
Old Apr 19, 2007 | 10:01 PM
64fordf100292
the reason that i suggested the duraspark conversion is it seems to be more reliable and parts availability . thats all. just goin off what I've heard. and the petronix sounds kinda iffy. that's all.
drof46
Jul 9, 2024 07:58 PM
drof46
Dec 30, 2014 08:30 PM
drof46
Sep 27, 2009 06:49 PM
drof46
Aug 10, 2009 06:05 PM
drof46
Jan 26, 2009 05:46 PM
