add grease fitting to upper control arm
Old Apr 10, 2007 | 08:21 AM
big red c222's Avatar
big red c222
After having to replace my upper control arm, because the ball joint isn't servicable. I though I'd fool around with adding a grease fitting. I wonder if this would extend ball joint life.
Old Apr 10, 2007 | 08:22 AM
big red c222
Old Apr 10, 2007 | 08:24 AM
big red c222
I don't think it sticks through far enough to damage the ball joint. the truck has about 60,000 miles. The grease inside was very dirty and getting hard.
Old Apr 10, 2007 | 10:39 AM
gui88ford's Avatar
gui88ford
nice work....looks good and i've been thinking about doing it to my truck also...
Old Apr 10, 2007 | 03:13 PM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith
Can you show the steps to do this? I don't understand how you disassembled the ball joint. Do you take it apart from the bottom, or does the top come off?
Old Apr 10, 2007 | 05:34 PM
4DOORSR's Avatar
4DOORSR
The ball joint can be replaced without changing the whole arm. Buy the joints from MOOG and press them in yourself. MUCH better quality joint. They don't call them "Problem Solvers" for nothing. None the less good idea...
Old Apr 11, 2007 | 06:52 AM
big red c222
The arm in the picture is the old one. I had to cut the heck out of it to remove the ball joint. You wouldn't need to do that to install the fitting. Just load up the appropriate drill bit with grease to catch the chips, drill and tap it. The reason I cut this one up was so I could see how far the fitting protruded through. You need to use, a fitting with a very short threaded area. About 3 threads. The lower ball joint is serviceable. Unless I'm missing something, the upper is not. ( I'll go to the moog site now to see)Once you have to replace it. It's too late. I was hoping to prolong the original.
hndacr
Feb 1, 2011 07:55 AM
Douglas DC-9
Jan 3, 2009 10:30 PM
PeteC
Jan 14, 2008 07:55 AM
BolderKeith
Nov 27, 2006 11:36 AM
dillinger
Sep 28, 2005 09:34 PM
