Sponsored by: Real Truck
Greasing ball joints
Old Jan 28, 2011 | 02:38 PM
hndacr's Avatar
hndacr
Quick question for you guys. Last year I installed Moog upper and lower ball joints. While changing the oil last week, I wanted to grease all the chassis fittings. When I installed the moog joints, it said to remove the 90* grease fitting on the upper to prevent clearance issues. How in the heck are you guys getting that fitting in place to grease the joints? Maybe my brain was not functioning because it was so cold outside last week. I know I greased them when I installed, but there is not enough clearance to get the 90* fitting in.
Old Jan 28, 2011 | 03:09 PM
Franko72's Avatar
Franko72
Molon Labe
If you have a 2wd, you can replaced the zerks with 45* degree fittings on the upper ball joints, and point them towards the front of the truck.
Plenty of room to get to em with a standard grease gun.
Not sure about the 4x4
Old Jan 28, 2011 | 03:13 PM
ZeroTucker's Avatar
ZeroTucker
The Moog 45's wouldn't work with my 2004 4x4. I just bought 90's and they clear no problem and there is enough room to get a grease gun on em.
Old Jan 28, 2011 | 05:59 PM
dagren99's Avatar
dagren99
Using 90's on my 00 - quick tip: install them with the zerk facing to the rear but pointed slightly towards the frame. Takes a few times to get them to tighten up that way but its worth it. This helps keep them from clogging which can be a pain as there isn't much room to use a zerk cleaning tool in there.
Old Jan 28, 2011 | 06:32 PM
sandmanf250's Avatar
sandmanf250
zerks
they can be a pain,but take your time a couple of buds to calm you down and git er done.
Old Jan 28, 2011 | 06:56 PM
wpnaes's Avatar
wpnaes
https://www.ford-trucks.com/forums/1...all-joint.html
A little help from the excursion side - 2000 4x4 v10, dana50.
No rub on the axle - Ford ball joints.
Old Jan 28, 2011 | 07:19 PM
swinehart07's Avatar
swinehart07
I just picked up a 90 deg grease gun adapter. It was about six bucks at tractor supply. It will slide sideways over the standard grease fitting. Thats how i grease my front upper ball joints on my 04 f250 4X4
Old Jan 31, 2011 | 09:06 AM
hndacr's Avatar
hndacr
maybe I was missing something because it was so cold outside. The height of the 90* fitting was greater then the clearance I had. I tried turning the wheels both ways and jacking the truck up by the axle and nothing helped. The fittings I have are the ones that came with the moog ball joints I put on the truck. The moogs also came with a plug that is in now in place of the 90* fitting. I wish I could remember how I greased them when I originally installed them. FYI the truck is 4x4.
Old Jan 31, 2011 | 12:32 PM
madscientist's Avatar
madscientist
I put moogs on my 2003 4x4 with the 90-degree fitting and they look exactly like the photos above.
Old Jan 31, 2011 | 12:38 PM
hndacr's Avatar
hndacr
I will get a picture tonight and post tomorrow. I really may have been braindead that day, it was 7* outside.
Old Jan 31, 2011 | 04:35 PM
wideglidewoody00's Avatar
wideglidewoody00
I bought the same grease gun adapter from TSC and it works great on the top ball joint with a straight zerk fitting. 2004 f-250 4x4
Old Feb 1, 2011 | 01:36 AM
RobH1965's Avatar
RobH1965
I jack the truck up and remove the wheel, laying on my back and having the u joint in the correct place I can install the 90 degree grease fitting in the upper ball joint with my two fingers. I tried a couple of times without removing the wheel but it was a no go. I noticed that the trucks at work leave the grease fittings installed however I would not try it because if it the u joint snaps it off it will take way longer than install/removing them during oil changes to replace the ball joint. Hope this helps.
Rob H 1965
Old Feb 1, 2011 | 07:55 AM
Snowseeker's Avatar
Snowseeker
Lots of room on a 2wd.
formerjeepguy
1997 - 2003 F150
Apr 21, 2017 07:52 AM
Big Black Dually
Feb 16, 2017 09:15 AM
spinella
Apr 29, 2013 10:52 AM
shaneinga
Apr 27, 2012 02:10 PM
Budman1962
Mar 20, 2008 11:50 AM
