1996 Ignition Control Module
Old Jul 6, 2016 | 11:52 AM
  #76
rla2005's Avatar
rla2005
You have to completely disassemble the distributor to change the PIP. This includes removing the distributor drive gear and it's associated roll pin. It's a pain, but doable.
I would save my money on parts, then take a little time to fully diagnose the issue. A LED tester comes in real handy...Ford Ignition Module Test. Fender Mounted Module (ICM).
While my money is on a faulty PIP, I always try to eliminate guess work.
Old Jul 6, 2016 | 01:06 PM
  #77
jben04's Avatar
jben04
now the PIP is situated in the actual distributor,, so instead of just swapping out the pip i can just swap out the distributor?
Old Jul 6, 2016 | 01:44 PM
  #78
subford's Avatar
subford
Yes you can but most distributors unless they are new have a bad PIP sensors in them. Some on here have replaced the rebuilt distributors four times before they get one with a good PIP sensor.
Old Jul 6, 2016 | 01:49 PM
  #79
jben04's Avatar
jben04
With all the headaches the e150 is giving me ,might just be worth picking up a Distributor and installing it.
On Rock auto they have a "Spectra Premium / Cooling Depot FD16 Distributor " for approx $70.
As i mentioned before my son in law is a mechanic so he can help install it.
Old Jul 27, 2016 | 02:14 PM
  #80
jben04's Avatar
jben04
Just a friendly update,,, had a new distributor installed,,everything running smoothly ,, fingers crossed
Old Jul 27, 2016 | 02:30 PM
  #81
rla2005's Avatar
rla2005
Glad to see you are on the path to resolution.
Tim Hodgson
170
Dec 29, 2025 02:44 PM
GoldCo
18
Jun 15, 2017 03:16 PM
autox65
Jul 31, 2016 05:27 PM
lawsonej
May 31, 2016 07:40 AM
