Draining Torque Converter on 97 Expy
Old Mar 31, 2007 | 12:26 PM
walterk15's Avatar
walterk15
At an impass.
I've drained the fluid out of the pan. dropped the pan and cleaned out the crap from the bottom of the pan. Pulled the Torque Coverter cover plug and BAM!!!!! No Torque Coverter Drain Plug. I read some where that you can rotate the engine by hand and have the Plug come around. How do you rotate the engine by hand????
Trans is a E40D.
Thanks
Old Mar 31, 2007 | 01:11 PM
amm888's Avatar
amm888
not all transmissions have the plug, don't know about the e40D myself.
you can rotate it by hand, i've read that post myself (and since forgotten the exact procedure) search for "torque converter" and you should be able to find the old post.
next time just make sure the plug is pointed down before you begin.
good luck,
al
Old Mar 31, 2007 | 01:43 PM
walterk15's Avatar
walterk15
Yep, found the Plug. Had my daughter pop the starter while I was watching for the plug to come around. Its small in size.
Old Apr 2, 2007 | 10:26 AM
buzzard's Avatar
buzzard
Glad you found it.
FYI, if anyone wants to turn the engine by "hand" just get a socket to fit over the crank bolt, attach a wrench and possibly a breaker bar and turn away. It should spin fairly easily.
Mustangoutcast
Jan 15, 2008 12:06 PM
BDalton
13
Jun 28, 2007 10:02 AM
Fourwheelinj1
Apr 11, 2007 09:22 PM
Point Blank
Jun 28, 2005 08:01 AM
jgates
May 22, 2002 09:33 AM
