Can anybody give me instructions on how to remove the interior door trim (front/passenger side) on my 00 expedition, 4x4?
Theres something squeaking inside the door mechanism when i drive thru rough roads. The sound comes up when the door locks are pressed down (locked) but the sound disappears when the door locks are up (unlocked).
I would like to see the inside, maybe something in the mechanism needs a little lubrication.
I don't remember where all the screws are, there's only about 2-3, but I do remember that the door panel pulls straight up to remove. There are no plastic clips anymore like 10-15 years ago.
General: 3 screws - 1 behind the courtesy light cover, 1 under the small triangular trim piece at the forward top corner, and 1 behind the door handle. Lift the panel up to remove.
