Sponsored by: Auxito
Transmision fluid
Old Apr 5, 2007 | 12:40 PM
c_cort's Avatar
c_cort
Well, all said and done I put in the Mobile1 ATF fluid. Dropped the pan, changed the filter, drained the TC. The transmission has never felt better. I've put about 450 miles on it so far and everything is still ok. The only thing is, it seems the newer bottles say MerconV and the older ones just Mercon, same part number and everything.
Old Apr 6, 2007 | 01:17 PM
paul812's Avatar
paul812
question guys...how long does it take to drain the TC? i'm goin for dropping the pan, replacing the filter, even thou it may not look dirty, i've heard too many bad stories abut the flush. not taking any chances. Almost went for that Pennzoil MUTI vehicle stuff, (Quicklube flush) thats supposed to be compatible with no telling how many other kinds, but was a bit leary of this. Also, has anyone tried using compressed air to get most of the oil out of the lines/cooler when disconnected? I believe in geting all the old out. BTW, this is a 2003 4.6 w/54k miles. No trailer towing or other hard working. I'm firm beliver in changing at 50k, but i live in small town, and oriellys is the only one who has the castrol V. Where do you get Motorcraft V? Thats another reason i like to get it all out, cause i dont like mixing oil brands. (this is first oil change) Maybe i.m a fanactic,,,but tranny's cost too much these days to replace. Esp. when its shifting so nice. No problems, just oil getting a lttle dark red. thanks guys!! paul
Old Apr 6, 2007 | 02:53 PM
mattyk6_bdr's Avatar
mattyk6_bdr
I don't think you can drain the TC of a 2003. I think the cut off for the drain valve was in 2001.
Old Apr 6, 2007 | 03:00 PM
genocidejunkie's Avatar
genocidejunkie
mercon v fluid now replaces all other transmission fluid- so says FORD. also, its not
necessary to put loctite on the toque converter drain plug, its a tapered pipe thread and will seal if properly tightened. the socket size is 11mm to remove the plug
Old Apr 6, 2007 | 05:27 PM
steve(ill)'s Avatar
steve(ill)
where does FORD publish that MERCON V can be used in place of Mercon in the older transmissions?
Old Apr 6, 2007 | 08:02 PM
genocidejunkie
i don't think that they have published this externally- we recieved notification at the dealership that merc v replaces, and is compatible with all other transmission flluids- merc 3 and type f.
Old Apr 6, 2007 | 09:34 PM
Lance1601's Avatar
Lance1601
Is the gasket reusable or does it come with the filter?
Old Apr 6, 2007 | 11:15 PM
paul812's Avatar
paul812
the factory pan gasket is reuseable. (unless torn or damaged) Still curious about the time it takes to drain a TC. As I am also going to do a oil change on the wives 2000 g. marquis. Same tranny i think. 4R70W. It should have a plug. thanks...paul
Old Apr 6, 2007 | 11:20 PM
paul812's Avatar
paul812
One other issue....why is Mercon V hard to find? all i can find is Castrol brand, (which i'm sure is good quality) , has anyone bought Ford oil from dealer? may sound crazy,,,, paul ......
Old Jun 23, 2007 | 11:28 PM
tj90's Avatar
tj90
Im flushing with old fashioned Mercon. $5.50 for 4 quarts at walmart. '97 4.6 truck has gone 140k miles with Mercon (regular flter and fluid changes every 30k miles) so why would I want to pay 2-3x the price for Mercon V? The bottle says specifically to not use on Trannys specifying Mercon V. I dont believe that Mercon V is backwards compatible, but Im sure there are some on the board that are more educated about this than myself.
Old Jun 25, 2007 | 12:54 PM
KingRanchMan02's Avatar
KingRanchMan02
If your dipstick has Mercon V stamped on it, then don't use plain old fashioned Mercon!
AliceSML79
Jun 24, 2015 10:25 PM
bronco6767
Nov 25, 2014 04:37 PM
deljac
Jun 6, 2014 08:04 AM
gomer450
Dec 4, 2013 12:51 AM
76xltcc
Jul 25, 2012 10:34 PM
