Sponsored by: Real Truck
transmision cooler line
Old Nov 20, 2014 | 10:42 AM
bronco6767's Avatar
bronco6767
So my 2000 f350 is leaking transmision fluid from the cooler line. It goes to the rear of the transmission, but where does it go to from there?
Old Nov 20, 2014 | 02:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The line to the rear of the trans is the return line from the oil to air cooler in front of the radiator.
Old Nov 20, 2014 | 03:09 PM
bronco6767's Avatar
bronco6767
the store near me does not have the line. So can I just get some metal tubing, flare the the end that goes into trans and then connect it to the rubber hose in the front below the radiator? Do you know what size tubing it would be?
Old Nov 20, 2014 | 03:45 PM
Mark Kovalsky
Yes you can. It is 3/8" line.
Old Nov 21, 2014 | 04:05 PM
bronco6767's Avatar
bronco6767
alright so I got the roll of 3/8 steel line. Any tips on removing the fitting that goes into the transmission end? Its pretty rusted and wont turn at all.
Old Nov 25, 2014 | 04:37 PM
bronco6767's Avatar
bronco6767
I just got the line done. It was not as bad as I thought it would be, I thought it would be harder to route the line properly.
1934mayflower
Feb 5, 2008 04:08 PM
Charger73400
1983 - 2012 Ranger & B-Series
Oct 11, 2007 01:19 AM
Jacob R
Mar 8, 2006 09:23 AM
orange78oval
1978 - 1996 Big Bronco
Feb 9, 2004 02:20 PM
Gary Harper
Jul 16, 2003 06:59 PM
