Bangs into reverse.
Old Mar 29, 2007 | 12:20 AM
Keepin It Real's Avatar
Keepin It Real
Bangs into reverse.
Got a '73 F100 2WD 302 C4 that seems to bang into reverse. Going into drive from park or neutral seem OK...Just into reverse makes a clunk, but functions fine once it's in there. Should I worry about this? Thanks.
Old Mar 29, 2007 | 03:30 AM
phil6608's Avatar
phil6608
Whens the last time you put new universal joints in it?
Old Mar 29, 2007 | 03:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C3AZ-4635-E .. U-Joint .. Dana-Spicer #1310 (all the joints on your driveshaft are the same, whether it's two or three).
Old Mar 29, 2007 | 10:04 AM
Keepin It Real
So you don't think it's the tranny? How hard is it for a somewhat mechanically challenged guy to replace u-joints and at what cost? Thanks.
Old Mar 29, 2007 | 10:18 AM
phil6608's Avatar
phil6608
It's not that hard of a job but can be a little tricky.
Last time I bought a set they were about 8 bucks a piece but that was a long time ago,,lol Should be less then $20 for one.
Old Mar 29, 2007 | 11:20 AM
Keepin It Real
What's the tricky part and do I need special tools?
Old Mar 29, 2007 | 04:42 PM
phil6608's Avatar
phil6608
Well if I remember right I think I had a hard time keeping the little end caps on the new ones wile putting them in and I had no tools.You will need a snap-ring tool and a socket set.
I also never did it before and just got under there and started messing with it.
Start with the back/take out the bolts in the U bolts then pull the shaft out of the trany.Then you can take the hole thing out from under the truck and work on it.
Old Mar 29, 2007 | 07:25 PM
Keepin It Real
Good info. Much obliged.
CampSpringsJohn
20
Oct 24, 2016 03:31 PM
schmeck
2004 - 2008 F150
Jun 25, 2015 05:53 PM
papajuls2964
Modular V8 (4.6L, 5.4L)
Sep 7, 2014 01:54 AM
Brian460
Sep 22, 2006 10:25 AM
Juggalo4life
General Automotive Discussion
Mar 2, 2004 05:02 PM
