Erractic shifting torqshift??
Old May 9, 2006 | 12:58 AM
Brian460's Avatar
Brian460
Cool Erractic shifting torqshift??
My torqshift has a very delayed reverse engagement, delayed drive, but not always. The 3-4 upshift will sometimes hit neutral for a few seconds then bang into 4th.
Here lately it doesn't seem to know what gear it is in sometimes, like I can manually put it in 1st yet it will remain in 3rd even at a dead stop.
It almost acts like an electrical problem.
Old May 9, 2006 | 07:37 AM
vloney's Avatar
vloney
the torqueshift has had an abundance of bad line pressure solenoids(supplier problem), if it kind of shudders when going into reverse and park, thats probably the problem
Old May 9, 2006 | 09:39 AM
Brian460's Avatar
Brian460
Are these solenoids easily replaced? How much do they cost?
Thanks
Brian
Old May 9, 2006 | 12:30 PM
vloney's Avatar
vloney
pull the pan and you can see all of them. you have to remove the valve body to change them though. if you arent familiar with trans operations, you might take it to a shop.
Old May 9, 2006 | 02:26 PM
Brian460's Avatar
Brian460
I can do a C-6 with no problem, if there isn't anymore to pulling the valve body on one of these I should be able to handle it.
How do you know for sure they are bad?
Old May 9, 2006 | 06:12 PM
vloney's Avatar
vloney
on the driver side of the trans close to the front of the pan, there is a pressure tap. it takes a 7/16 wrench to remove. you have to measure pressures at different gear selections. there is a set of specs on this. you need to get these specs to decide which solenoid is bad
Old May 9, 2006 | 06:32 PM
Brian460's Avatar
Brian460
ok, got tranny gauges now I need the specs.
Is that a standard or a metric pipe thread in the tranny?
Old May 9, 2006 | 07:09 PM
vloney's Avatar
vloney
I think its standard thread. At idle you need p & n---50psi r----100 d----70 3,2 & 1----80 psi
Old May 9, 2006 | 07:11 PM
Maxium4x4's Avatar
Maxium4x4
<TABLE cellSpacing=0 cellPadding=3 border=1><CAPTION>This is getting tricky, I'm not sure on the pressure chart you want...
NOTE: Actual and commanded pressures will vary based on calibration and transmission adaptive strategies. All pressures listed are approximate.
</CAPTION><TBODY><TR><TH vAlign=bottom align=middle rowSpan=2>Gear </TH><TH vAlign=bottom align=middle colSpan=2>Line Pressure — kPa (psi) </TH><TH vAlign=bottom align=middle colSpan=2>Commanded (a) — PC A pressure kPa (psi) </TH></TR><TR><TH vAlign=bottom align=middle>Idle Speed </TH><TH vAlign=bottom align=middle>WOT Stall </TH><TH vAlign=bottom align=middle>Idle Speed </TH><TH vAlign=bottom align=middle>WOT Stall </TH></TR><TR><TD vAlign=top align=middle>P, N </TD><TD vAlign=top align=middle>344 (50) </TD><TD vAlign=top align=middle>— </TD><TD vAlign=top align=middle>172 (25) </TD><TD vAlign=top align=middle>— </TD></TR><TR><TD vAlign=top align=middle>R </TD><TD vAlign=top align=middle>689 (100) </TD><TD vAlign=top align=middle>2,206 (320) </TD><TD vAlign=top align=middle>413 (60) </TD><TD vAlign=top align=middle>1,407 (204) </TD></TR><TR><TD vAlign=top align=middle>(D) </TD><TD vAlign=top align=middle>483 (70) </TD><TD vAlign=top align=middle>2,206 (320) </TD><TD vAlign=top align=middle>276 (40) </TD><TD vAlign=top align=middle>1,379 (200) </TD></TR><TR><TD vAlign=top align=middle>3 </TD><TD vAlign=top align=middle>551 (80) </TD><TD vAlign=top align=middle>1,793 (260) </TD><TD vAlign=top align=middle>331 (48) </TD><TD vAlign=top align=middle>1,172 (170) </TD></TR><TR><TD vAlign=top align=middle>2 </TD><TD vAlign=top align=middle>551 (80) </TD><TD vAlign=top align=middle>1,482 (215) </TD><TD vAlign=top align=middle>338 (49) </TD><TD vAlign=top align=middle>952 (138) </TD></TR><TR><TD vAlign=top align=middle>1 </TD><TD vAlign=top align=middle>551 (80) </TD><TD vAlign=top align=middle>1,861 (270) </TD><TD vAlign=top align=middle>338 (49) </TD><TD vAlign=top align=middle>1,213 (176) </TD></TR></TBODY></TABLE>
Old May 9, 2006 | 07:13 PM
Maxium4x4's Avatar
Maxium4x4
Go with vloney.....looks like he is on it...
Edit: pay no attention to the Command a....that is for a Ford technition
Old May 9, 2006 | 10:45 PM
Industrial_dude's Avatar
Industrial_dude
from personal experience your tranny is done and youll need a new one. Your clutches are smoked and your solenoids are contaminated with metal particles.
Old May 9, 2006 | 10:49 PM
Brian460's Avatar
Brian460
Industrial, I would be the first one to support that idea except, for the fact that sometimes it will behave completely normally.
It also sometime hits neutral when making a right hand turn.
Old May 10, 2006 | 07:31 AM
vloney's Avatar
vloney
the solenoids I have replaced when you do the pressure checks, there is a wild fluctuation in pressure readings. As far as going into neutral when turning right, dont turn right---YUK, YUK
Old May 18, 2006 | 09:35 AM
Brian460's Avatar
Brian460
Does it matter if the tranny is hot or cold to perform this check?
Old May 18, 2006 | 10:12 AM
Brian460's Avatar
Brian460
OK I did the check with the tranny cold.
My results were that P,N idle was <25psi
1,2,3,D,R all caused the gauge to fluctuate wildly like going from 0 to pegging out a 300psi gauge very rapidly.
Sometimes it would calm done and act normal
when it would I got
D idling 125psi-175psi
2 idling 93psi against the stall 225psi
Which soleniod do I start with? Or do I just replace them all?
