Sponsored by: Real Truck
remote entery reprogram
Old Mar 22, 2007 | 05:47 PM
HENDEL's Avatar
HENDEL
Post remote entery reprogram
can any body tell how can i reprogram my 05 e-350 supper duty
15 passenger van the remot stoped working 2 or 3 dayes ago
i replaced batery and still does not work it sayes in oners manuel
turn key 8 times rapidly for 10 seconds stll nothing
Old Mar 22, 2007 | 06:07 PM
Beerstalker's Avatar
Beerstalker
First, is your vehicle entering the program mode? The doors should lock unlock if you did it right.
It says to cycle the key between off and on 8 times in 10 seconds not for 10 seconds. Also be sure you are just going between off and on (not start), not all the way back to lock (the position where the key comes out). Finally be sure to end in the on position.
If the van is going into program mode and you just can't get the remote to work double check that the battery is installed correctly, and check the voltage on the battery to make sure it is good. If you are still having problems the keyfob might have gone bad, check ebay or a ford dealer for a replacement.
Old Mar 22, 2007 | 06:44 PM
HENDEL's Avatar
HENDEL
i did do it the way it should i hear it unlock and lock but remote still does not work
i put a new battry in it still nothing
Old Mar 22, 2007 | 06:46 PM
HENDEL's Avatar
HENDEL
Old Mar 22, 2007 | 07:10 PM
Beerstalker
If it is entering the program mode, and pushing the button on the remote does nothing then either:
1. The new battery is installed wrong, pull it back out and check.
2. The new battery is already dead (Doesn't happen often but it does happen).
3. The Keyfob is broken buy a new one.
Old Mar 22, 2007 | 07:24 PM
HENDEL's Avatar
HENDEL
i do not understand
what you mean buy a key you mean the door key
the is not bad
Old Mar 22, 2007 | 07:29 PM
Beerstalker
keyfob = remote transmitter
I'm not trying to sound mean but is english not your first language? If not you should really let people know so they try to explain things very simple.
Old Mar 23, 2007 | 09:31 AM
hydro_37's Avatar
hydro_37
If all else fails. Take it to a dealer and let the service department help you.
08REDXLT
2004 - 2008 F150
17
Jan 25, 2015 06:39 AM
CaptKen
Sep 19, 2013 06:17 PM
esco24
May 27, 2007 07:36 PM
plb7732
Apr 3, 2006 10:01 PM
ExpoBoi99
16
Jul 28, 2004 09:56 PM
