anyone know how to reprogram the keyless entry on a 02 f350 remote just stop working changed the battery no luck parking lights flash when i lock the door man.
I just bought 4 new remotes and had to go through the procedure to get them working. I'm in my place of work at the moment, but I have the written instructions in my glove box. If you can wait, I can get it written up ofr you early this evening, probably by about 8pm central time.
In the meantime, you can try what I have stored in my (sometimes faulty and rather short lifespan) memory banks. You don't have anything to lose by trying.
READ thoroughly through all steps before trying it out.
1. Get in the vehicle with the doors unlocked and the doors closed.
2. Insert your key into the ingnition.
3. Eight times, cycle the ignition switch ON and OFF (WITHOUT starting). NOTE: you have to do this quickly within 10 seconds, and the LAST time, you have to leave the ignition in the ON position.
4. The door locks will cycle once to confirm that your in the programming mode.
5. Press any button on your remote.
6. Turn your ignition back to the OFF position and the locks will cycle once again indicating that you have left the programming mode.
You should be good to go... I think. If you try this and it works, post a reply back so I won't dig out the instructions unnecessarily. I'll check back in here before I leave work at 6-6:30 PM.
