fuel pressure shim
Old Mar 20, 2007 | 05:21 PM
deetown's Avatar
deetown
fuel pressure shim
I was wondering does shimming fix the spring fatigue or just to increase the fuel pressure? I'm wondering because I read that the stock fuel pressure spring begins to fatigue 10% at 10,000 cycles so with 230,000 miles I was wondering how much weaker my fps is and if I should do the shim mod. Thanks
Old Mar 20, 2007 | 05:45 PM
Pocket's Avatar
Pocket
Some are at a lower pressure than others brand new from the factory. Typically, you would find that your fuel pressure is anywhere between 44-56 psi in stock form. Bumping up the fuel pressure does help to quiet the idle a bit, and makes the engine feel a bit peppy.
Old Mar 20, 2007 | 07:44 PM
Mach1's Avatar
Mach1
Put the gauge on there and see where you are. The fuel pressure is a very good mod...you want around~70psi.
Old Mar 20, 2007 | 09:29 PM
John311t's Avatar
John311t
I just did this last week, and i just put the bb in their and it went right up to 75lbs. The idle is quieter, and it feels(but anytime i do something i feel something different) a bit better off the line. I havnt experimented yet with it since im going to homebrew up regulated return so once that happens i wouldnt have to experiment with the shims.
lilrobo
May 3, 2014 08:32 PM
MONAVIERONJON
Jun 28, 2013 08:21 PM
Aberasturi_c
16
Mar 25, 2008 11:00 AM
John311t
34
Mar 29, 2007 11:16 AM
martyfowler
Feb 20, 2003 05:36 AM
