power steering
Old Apr 27, 2014 | 02:24 PM
lilrobo's Avatar
lilrobo
power steering
i bought a kit from borgfson and i took my pressure valve apart and i have 1 shim now ,, by what the instruction say and the problem is ( hissing when turning ) what should i do ? no shims ?
thanks
no shims 1350
1 shim 1200
2 shims 1100
3 shims 1000
4 shims 850
5 shims 700
Old May 3, 2014 | 05:48 PM
lilrobo's Avatar
lilrobo
well i got the kit and took mine apart and i had 1 washer already so i added 1 more to try it and it does the same thing dont seem as to as bad , seems like its starts to hiss a little after you turn a little . i mean you turn the wheel about a 1/4 turn and it starts , so i will do another washer . the power steering is about the same i would have though that i would loose some power , back under the hood
thanks
Old May 3, 2014 | 08:17 PM
AXracer's Avatar
AXracer
keep adding shims until the noise stops or the steering gets too stiff.
Old May 3, 2014 | 08:32 PM
lilrobo's Avatar
lilrobo
I guess this how i learn, i just hope the noise stops before my power steering lol
Thanks
59INA40
Sep 22, 2008 06:16 AM
FordGuy1280
Aug 9, 2006 11:21 PM
LarryA
Bronco II
May 28, 2006 09:36 PM
Spooky
Apr 1, 2004 06:55 AM
ron351w
Mar 19, 2001 09:54 AM
