Which Diff do I have?
Old Mar 11, 2007 | 03:21 PM
GRWRVING's Avatar
GRWRVING
My Ford E350 dual wheel 1998 motorhome has a slight leak at the pinnion seal. After reading my book on replacement there seems to be 3 kinds used on that year. How do I tell which rear end differential I have?
Old Mar 11, 2007 | 03:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Find the VIN plate/sticker, and look for the axle code. The code can be decoded and will tell you what axle type you have, the ratio, and the axle weight capacity. If you have a cutaway (body cut away behind B pillar), the VIN will be on either the door face, or the door post (B pillar).
There is also a metal tag on one of the rear axle center section bolts with the Ford axle ID number, and numbers/letters like 61.1 or D70, etc. and the ratio may be listed too.
Capt.Schenk
6.7L Power Stroke Diesel
13
Mar 23, 2017 02:23 PM
fordboy67
Feb 23, 2015 10:28 AM
Trackerrrr
May 27, 2014 05:37 AM
aRKToS
13
May 15, 2009 08:13 PM
bigeric
Aug 13, 2001 08:51 AM
