Which dipstick do I use??
Old May 25, 2014 | 11:01 PM
Trackerrrr's Avatar
Trackerrrr
I discovered I have TWO oil dipsticks on the 460 in my '83 F350. There's one in front of the engine by the distributor and one on the left side going down to the oil pan. Which one is right???
Old May 26, 2014 | 06:06 AM
CountryBumkin's Avatar
CountryBumkin
Change the oil, put in 5 quarts, and see which one shows full on the stick.
My guess is that they both will show the same level.
My stock 460 timing cover has a provision for a dipstick but has the "plug" in the dipstick tube opening - so I use the pan located dipstick.
Old May 26, 2014 | 07:17 AM
82F100SWB's Avatar
82F100SWB
Your pan should be a rear sump so the rear stick is the one that should get used.
Old May 26, 2014 | 02:45 PM
Franklin2's Avatar
Franklin2
Yes, I don't see the front even going in all the way unless they cut it off and stuck it in the tube. If it is in there maybe they jammed it in there and it's curled against the oil pan.
Old May 27, 2014 | 04:44 AM
Ken Blythen's Avatar
Ken Blythen
This is what I've done in the past, too (but I think you mean six quarts).
Old May 27, 2014 | 05:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Look on both dipsticks for their stamped ID number, post what they are. The ID number will be similar to this: E3TE-6750-AB
Trucks (gassers) take 6 quarts with a filter change.
460towrig
Dec 11, 2015 11:01 AM
TobaccoBarn460
Jan 18, 2015 11:10 PM
xjpilot
Mar 8, 2012 10:02 AM
Regta
Mar 27, 2008 05:40 PM
e250guy
Sep 10, 2006 06:43 PM
