OD off button broke off
Old Mar 9, 2007 | 09:13 PM
psd tuner's Avatar
psd tuner
i have a '96 f-250 with a auto trans. the od off button broke off, i am woundering what is the best way to fix the problem. I am goin to replace the whole shifter. am i goin to have to take the whole column off? I think all that is holding the shifter is a pin, but where does the wiring harness plugin on the column? Any info. would be greatly appreciated.
Old Mar 9, 2007 | 10:10 PM
brown 4x4's Avatar
brown 4x4
No, you don't have to remove the column. Take the plastic covers off and you should see the shifter and the wires plug in somewhere close. I did one awhile back and it didn't take long at all.
mhg's Avatar
mhg
the button has a ring of plastic that snaps on the end
of the shifter
pop it off then the switch will just unplug
three prongs on the end of the switch
real easy to do
Old Mar 11, 2007 | 08:23 PM
psd tuner's Avatar
psd tuner
i will take it apart tomorrow, i think all i have to do is take off the shift boot, the pop the pin, and unplug the harness where ever it is. thanks for the info.
Old Mar 12, 2007 | 06:30 AM
alz's Avatar
alz
This is what you're looking for.
http://broncograveyard.com/bronco/i-...on_and_cap.htm
TexasGuy001
19
Jul 28, 2011 10:25 AM
lucysw
Jan 1, 2011 11:53 AM
nathant
May 22, 2010 09:11 AM
jimwilsonmasonry
May 25, 2008 02:46 PM
69ford99
1978 - 1996 Big Bronco
Sep 25, 2006 01:07 PM
