mallory problems!!!!!!!
Old Feb 20, 2007 | 10:52 PM
toyotaguy's Avatar
toyotaguy
Cool mallory problems!!!!!!!
i have a 351w with a mallory unilite distributor this past weekend i was playing around with it in the desert and suddenly it stopped running. well after some time i found the problem. inside the distributor down in the bottom is an advance plate that you can limit the amount of advance in this dis. well one of the stops in the bottom broke off and jammed the dis while running causing it to turn and mess up the timing. my question is has any one heard of this problem and know why it would happen? and is a msd dis a better part? i have also heard that unilites with there optic windows dont like dusty conditions and this can cause the ign to fail.
thanks justin
Old Feb 21, 2007 | 12:34 AM
Mil1ion's Avatar
Mil1ion
Maybe try the electrical forum.
This aftermarket distributor has nothing to do with 73-79 trucks
Old Feb 21, 2007 | 09:22 AM
beartracks's Avatar
beartracks
I had a Mallory Unilite that dropped a small screw out of something (don't remember what). I "E" mailed them and they had me send it in and rebuilt it. The screw had jammed and generated a ton of metal dust. They also rebuilt an older one for me that plain wore out. Both for free.
I obviously like their service but would not use a Unilite again. I had too many problems with them.
Old Feb 21, 2007 | 07:55 PM
toyotaguy's Avatar
toyotaguy
thanks bear tracks
im still up in the air, to fix it or go to an msd
any one else have any tips
thanks
justin
Old Feb 22, 2007 | 07:06 AM
LxMan1's Avatar
LxMan1
I prefer the Mallory myself. Contact them thru Mr.Gasket. They bought them out when Super Shops went out of business (I used to work there). Mallory is very good about taking care of their customers.
Old Feb 22, 2007 | 09:50 AM
beartracks's Avatar
beartracks
One of the problems you'll find is locating a good dizzy that has vacuum advance. You really need it for performance/4 wheel drive. I'm presently using Accel with a 300+ module.
Old Feb 23, 2007 | 08:52 AM
Franklin2's Avatar
Franklin2
If you do not have a custom advance curve, you could use a Ford duraspark and use it to trigger a MSD 6A.
Old Feb 23, 2007 | 01:40 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Distributor
thanks justin
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.c...stributors.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
bubbadford
May 25, 2009 11:28 PM
toyotaguy
Feb 24, 2007 06:23 AM
Jims1969F250
Jan 6, 2007 10:54 PM
lesvan
Aug 29, 2004 04:32 PM
Mistro
Oct 24, 2002 08:34 PM
