Sponsored by: Real Truck
overhead MPG
Old Feb 13, 2007 | 07:43 PM
scwirenut's Avatar
scwirenut
overhead MPG
I just aquired a 99.5 f350 drw/crew 4x4 , I have read that the overhead display for mpg is not real accurate and cant be trusted, I was curious as to why? what variables does it use to get its calculations? how does it work, do any of you have one that is accurate? what is the average amount it is off?
Old Feb 14, 2007 | 06:31 AM
scwirenut's Avatar
scwirenut
bumping it up
Old Feb 14, 2007 | 07:11 AM
Pocket's Avatar
Pocket
It varies quite a bit. The overhead display goes by engine load, speed, rpm's, gear, etc. Any power enhancements or modifications (ie. tire size changes) can throw off the mileage estimate even more. You can hand calculate mileage and then compare it to the overhead display to see if yours is accurate or not.
Old Feb 14, 2007 | 08:20 AM
PHWLEE's Avatar
PHWLEE
I agree that the overhead console's MPG is not accurate to say the least. I don't even have the MPG's on display. I leave the ambient temperature and direction on display and use manual calculations for getting my MPG's.
Old Feb 15, 2007 | 01:54 PM
scwirenut's Avatar
scwirenut
I just learned by reading my manual that the MPG is the Average since last reset, that could have been 50,000 miles ago!, I reset it and after a tank or 2 Ill see if its close, has everyone been resetting it? If so, how often, every tank, every month?
Old Feb 15, 2007 | 04:04 PM
Pocket's Avatar
Pocket
I don't use mine anymore. I've reset it again and again testing out how accurate it was, and it's always off by at least 1.5 mpg or more.
Old Feb 15, 2007 | 04:32 PM
Rich in CO's Avatar
Rich in CO
Mine does the same as Pockets. It seems to always be off by 1.5 mpg
Old Feb 16, 2007 | 06:14 AM
F250tuff's Avatar
F250tuff
Same here. If my overhead says 16.5 MPG, it will hand calculate to about 15 MPG.
Old Feb 16, 2007 | 08:10 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I must be lucky mine was dead on with hand calculations. Then I got PMS and added jodys chip. That really played head games with the display it seems to think I get about 22-25mpg at 80mph. Reality calculations at that speed in the 15's. I reset mine on every fill up just for grins. I try to fool myself into beleiving I get 20-25 mpg sometimes.
Old Feb 16, 2007 | 08:27 AM
davlan88's Avatar
davlan88
Mine has been reading 14.8 lately, but hand calc'd it last night and got a 15.3. How are you guys hand calc'ing it? I have been resetting the tripmeter at fill up, then dropping down the tank as far as possible, taking the tripmeter reading and adding the miles left to empty readin and dividing by 30.
Old Feb 16, 2007 | 09:18 AM
lariat79sc's Avatar
lariat79sc
I reset after everytank at fill up. It isn't dead on for me. It is about a 2 tenths of a mpg off at the end. Close enough to see if something isn't kosher though.
Old Feb 16, 2007 | 02:33 PM
F250tuff's Avatar
F250tuff
I don't use the miles-left-to-empty when hand-calculating. I reset the trip when I top-off. The next time I get fuel, I pump the fuel, then divide the trip reading by the number of gallons I just finished pumping. Out of the 40 tanks of fuel I've ran through, all except 4 tanks of it were pumped from the same pump at the same station, which helps take some error out of the calculations (vehicle sitting in same position each time, pump flow is the same each time, etc).
Old Feb 16, 2007 | 04:43 PM
gunslinger0074's Avatar
gunslinger0074
I think F250tuff is right on. I can really screw my MPG by topping off the tank when I fill up. When the nozzle clicks off, another 6 to 6.5 gallons can be added. The fuel gauge will stay on full for 50-75 miles before moving.
Old Feb 17, 2007 | 02:42 AM
PMDRACER's Avatar
PMDRACER
The mpg display on my '99 is pretty much dead-on. It's the miles to empty part that's at least 50 miles optimistic.
Put it to you this way; I have the 32 gallon gas tank and last week I pulled in for a fill up, putting 31 gallons in, and the display said I still had 52 miles to go.
trsimmons25
Apr 11, 2012 07:58 PM
Loopy
Dec 9, 2010 05:21 PM
teppler
Feb 4, 2010 06:41 PM
TN97STROKE
Apr 4, 2008 03:35 PM
4X4 IN REFUGIO
Nov 13, 2005 06:10 PM
