1978 - 1996 Big Bronco
rear window power fix?
Old Nov 24, 2002 | 01:55 PM
nixvet's Avatar
nixvet
Help!
I rebuilt the rear window motor with the kit and new gear but cant get the window to go back in so I can lift the tailgate!!! How to I release the tension so I can get the window in and lift my gate???
Thanx
nixvet
please answer here or email me at nixvet@***.net
1988 Ford Bronco XLT 5.8
Old Nov 24, 2002 | 02:47 PM
Bronco Billy's Avatar
Bronco Billy
Well, if you've done all the repairs nessesary, all you should have to do is Close the latch fingers on the drivers side of the gate. (simply push them down with your thumbs till they click in the latched position) This makes the gate "think" it's closed; then insert your key in the switch, and lower the window - into the gate. THEN, pull the latch handle to re-open the 'fingers', before closing the tailgate!
Hope it works - and I hope you inspected/replaced the nylon rollers on the regulator arms... (just did mine this week)
GOOD LUCK - FROM THE OREGON MUD!
Old Nov 24, 2002 | 04:15 PM
nixvet's Avatar
nixvet
Thanx alot...! I was hoping it was something simple...I'm glad I got your answer before I attempted what the "power window expert" at our local parts store suggested.
Later...
nixvet
Old Nov 24, 2002 | 07:59 PM
kenpoore's Avatar
kenpoore
Another thing you may wish to try is to use a paper clip to short the wire connected to the latch on the drivers side of the tailgate. It is hard to reach but this will allow the window to be raised or lowered with the door in any position. You may want to check the allignment of the door striker plate. if the striker plate is misaligned or the nylon bushing is missing or cracked it may keep the window motor from operating.
Old Nov 25, 2002 | 12:47 AM
Big 89 Bronco's Avatar
Big 89 Bronco
TexasRedX
Oct 27, 2015 10:28 AM
Autoarcheologist
Aug 21, 2015 11:06 AM
Mr. Bob
17
Oct 5, 2014 11:28 AM
nixvet2000
23
Jan 31, 2004 04:34 PM
AbadDriver
Jun 22, 2003 03:16 PM
