1978 - 1996 Big Bronco
Disassemlbing tailgate
Old Jun 19, 2003 | 12:09 PM
AbadDriver's Avatar
AbadDriver
How would i dissassemble the tailgate so i can attempt to fix the wiring to get a working rear window?
Thanks
Tim
Old Jun 19, 2003 | 12:14 PM
mrwizard's Avatar
mrwizard
There is an access panel on the inside of the tailgate. Remove it and you will have access to the internals. Not easy access, but access none the less.
Old Jun 19, 2003 | 12:20 PM
steve83's Avatar
steve83
You don't really have to "disassemble" it - just pull the access panel from the inside (if you have carpet, remove that first) and look inside. If your glass won't go down, you're lucky because it's in the way when you open the t/g. I used to have a bunch of pics online, but the site dumped 'em last weekend.
Use a 12V test light and the Haynes wiring diagrams to find out where the power stops. If you find the round 4-pin connector just inside the L frame rail at the back bumper, you should have ground on the 2 purple wires (P/LG & P/LB) and 12V at all times to the Bk/Wh wire. With the key on, one of the purple wires should go hot (12V) when you operate the dash switch.
Old Jun 19, 2003 | 09:41 PM
AbadDriver's Avatar
AbadDriver
the access panel is off. but the wires are everywhere. the glass is down so most of the wires i cant reach(im a bigger guy) is there a way to take it even more apart so i can fix the wires?
Tim
Old Jun 19, 2003 | 09:47 PM
greystreak92's Avatar
greystreak92
Unfortunately, no the acess panel is the only way into the "guts" of the T-gate. If you can get the window to go UP once the gate is open and SUPPORT THE GLASS, there is a LOT more room to vaneuver in there.
Old Jun 19, 2003 | 11:06 PM
steve83's Avatar
steve83
If you reach behind the center divider, you should feel a rod running straight down. Make sure it's pushed all the way down, and MAKE REALLY SURE the glass is NOT still in the groove of the camper shell, then pull the handle and open the t/g. That should make it a lot easier to work on.
If you can pull the 4 nuts that hold the glass on its tracks, you can pull it out of the way.
Whaddaya mean: "the wires are everywhere"? Someone ransacked the t/g wiring and spread them out all over inside it?
Old Jun 20, 2003 | 10:04 PM
AbadDriver's Avatar
AbadDriver
wires are everywhere----theres like 4 connectors connected.
1. window motor
2. r side latch
3. left side latch
4. defrost
basicall theres wires coming off those but they lead to nowhere.
In theory if i unbolt the window from the regulator i should be able to just push it up right?
Thanks
Tim
Old Jun 20, 2003 | 10:50 PM
steve83's Avatar
steve83
Yeah, that's what removing the 4 nuts does. I just realized you can look it up at this link.
Old Jun 21, 2003 | 10:15 PM
AbadDriver's Avatar
AbadDriver
Thanks for the help guys....i got it to work....kinda. bassically when i said the wires were a mess, 2 of the wires were the power for the the motor. so we(me and a brother) hooked up a battery charger nd clipped it on. up it went. to bring it down, we reversed it. ghetto but it worked.
as i said, thank yous for the help.
Tim
Old Jun 21, 2003 | 11:22 PM
steve83's Avatar
steve83
If the switch in the t/g wouldn't operate it, then the problem is most likely that the driver's latch isn't closing fully, which is where the safety interlock switch is. To test, roll the glass down, open the t/g, then close the driver's latch by hand - BOTH parts. Then see if either switch works. If it does, put the glass back down and use the inside handle to open the latch, and get a T-50 bit to reset the strike bolt ~1/16" rearward.
If it's not the interlock, then it's the dash switch. That's where the motor has to ground thru regardless of which switch you use.
If it was a power problem (a blown fuse), then one of the switches would work.
Old Jun 22, 2003 | 03:16 PM
chuck641's Avatar
chuck641
i cut the wires goin to the safety switch and twisted them together, that solved all my problems.
Jason
Ripcity
Sep 19, 2013 08:52 AM
tsessions77
Jun 1, 2013 03:52 PM
Blown284
Maryland Chapter
23
Mar 21, 2012 03:58 PM
tshearn
6.4L Power Stroke Diesel
20
Feb 18, 2010 06:18 PM
radsickt
Nov 5, 2000 03:17 PM
