Different injector question
Old Feb 27, 2007 | 10:32 PM
JMorton's Avatar
JMorton
Haven't tried yet. It's not bad on the lowest setting, on the two high settings it really smokes, it would never pass on those settings. Would probably be fine if you have a stock setting or removed the chip/programmer.
Old Feb 28, 2007 | 07:04 AM
ruger761's Avatar
ruger761
without pulling the valve covers is there a way to tell what factory injector i have?
Old Feb 28, 2007 | 08:28 AM
tjbeggs's Avatar
tjbeggs
yes just tell us about your truck. best hting to do is fill out your signature. go toward the top of the page and on the right hand side it says user CP click that and go to edit signature. put as much info about your truck as you can. year, trans, 2wd or 4wd, any mods etc.
Old Feb 28, 2007 | 09:11 AM
ruger761's Avatar
ruger761
Oh cool deal, still figuring new stuff out about this site. Ok added all the info to my signature about my truck.
Old Feb 28, 2007 | 11:22 AM
tjbeggs's Avatar
tjbeggs
Ok as long as your truck is not a california emmisions model you have AA single shot injectors. If your truck is a CA emmissions it will have a valve cover sticker that says california emmission, a black hockey puck type thing on the back side of the mechanical fuel pump in the valley. If it a CA model you have AB split shot injectors. ALso you if you can find the 4 digit PCM calibration code that will tell you what emmisions standard you are set up for. If its a MME* code thats the california automatic code. if not then you will probably have a TD** code.
Old Feb 28, 2007 | 11:52 AM
ruger761's Avatar
ruger761
Thanks for the good info. Its a non california truck.
Old Feb 28, 2007 | 11:58 AM
tjbeggs's Avatar
tjbeggs
you got AA's then.
Old Feb 28, 2007 | 07:03 PM
dpatterson2005's Avatar
dpatterson2005
i thank you for your information i also hope that it will pass the emissions test again thanks
Old Feb 28, 2007 | 10:26 PM
JMorton's Avatar
JMorton
If you go with the 160's, you'll probably want to get rid of that .84 turbo housing and put the stock one back on. You'll also want to get an intercooler.
Old Mar 1, 2007 | 07:13 AM
ruger761's Avatar
ruger761
Ya thats what i have heard about the housing, so kept the stock one. Thanks
Old Mar 4, 2007 | 01:25 AM
RocknXJ's Avatar
RocknXJ
My truck is a '96 F250 auto 4x4, CA truck. What injectors should I have?
I read in one place that they are AE injectors? If so, any idea what they flow, and are they split shot, and what's the significance of split shot?
Thanks,
Old Mar 4, 2007 | 06:51 AM
tjbeggs's Avatar
tjbeggs
you should have AB split shot injectors. the split shots are mainly for emissions thus the california models use of them. they also make for quieter engine operation. they flow 120cc from what I have read.
dougie brault
Jul 15, 2012 08:54 AM
Jessef250
Sep 11, 2011 09:00 AM
danielwd
1983 - 2012 Ranger & B-Series
Jan 2, 2011 10:18 PM
88PONY
Oct 31, 2009 05:29 PM
jjlrrw
Modular V8 (4.6L, 5.4L)
Aug 17, 2006 12:04 AM
